02-20-2019 03:35 PM
Using CUCM 10.5 and Cisco 8865/9971 phones with SIP loads. I have calls going between them successfully and calls to PSTN working correctly. Calls from the phone to the CUCM and out to PSTN correctly have SDP in the initial INVITE. However, calls from the CUCM to the phone do not have Early Offer. Enabling MTP Required on the Device does cause the CUCM to send Early Offer, but that is not a practical solution.
Phone -> CUCM - Early Offer
CUCM -> SBC - Early Offer
CUCM -> Phone - Delayed Offer
Any ideas?
02-20-2019 09:52 PM
You can use Best Effort (No MTP Inserted) for early offer support for voice and video. This will send an early offer by call manager where ever it is possible. you can find below snapshot for better understanding.
You can find this configuration element in SIP Profile.
Shalid
Please rates helpful posts.
02-20-2019 10:17 PM
That worked for the CUCM -> SBC INVITE. I am trying to resolve the CUCM -> Phone INVITE. Enabling Early Offer (Best Effort) in the SIP Profile did nothing for the INVITE from the CUCM to the Phone.
So this works:
Phone --EO--> CUCM --EO--> SBC --> PSTN
This does not:
PSTN --> SBC --EO--> CUCM --DO--> Phone
08-12-2022 01:15 AM
Hi Courtschuett,
Did you finally figured out an answer for your question?
I have exactly the same question than you. I would be really grateful if you share the answer with me (if you have it)
Best regards,
08-12-2022 07:59 AM
Out of curiosity may I ask what use case you have for having early offer sent from CM to the phone?
11-30-2022 02:22 AM
Hi, currently having the same challenge as the op: I need CUCM to use EO to a 3rd party SIP device.
The use case here is that we want to test the open source "Blink" SIP softphone, which seems to accept EO INVITEs only. It responds with "488 Not Acceptable" in case of DO INVITE.
Currently my only workaround is also to enable "MTP required", which of course does not scale. Any SIP Profile options as mentioned before only apply for SIP trunks (i.e. "Best Effort" etc.).
BR, Steffen
11-30-2022 08:13 AM
The phone configuration page in CUCM also has SIP Profile. Have you tried applying a SIP Profile on the phone configuration page that includes the 'Best Effort (no MTP)' setting?
Maren
