Network Connectivity Issue in CUCM 8.6 over VMware UC210
cristian.munoz
Level 4
Level 4
This is a new installation and I have a network connectivity issue, in my CUCM 8.6 over VMware VSphere 5 UC210. In the vSphere client I have connectivity to default gateway and to all networks. But, in my CUCM , using the CLI, I can't ping to or from the CUCM.
The eth0 have the link detected yes and the status is up.
Any idea?
TIA
Cristian.
13 Replies 13
Chris Deren
Is the proper vSwitch assigned to the virtual machine?  Does that vSwitch include the proper NICs?
Chris
Dear Chris
The conectivity is by a switch with cannel port configuration.
For the vSphere conectivity, please see below:
TIA
Cristian
Hi Guys
Any idea?
Anyone has this happened?
TIA
Cristian
So, you can get to ESXi, but not the CUCM?
What if you remove the VLAN from the vSwitch?
Can you post "show network eth0" from CUCM CLI?
Chris
Dear Chris
1.- you can get to ESXi, but not the CUCM?
Yes, right.
2.- What if you remove the VLAN from the vSwitch?
Set Vlan ID none, I loss the conection to IP 10.199.0.6 . Set Vlan ID 1, I loss the conection to IP 10.199.0.6. Set Vlan ID 4095, I have connection.
This is the config in the switch.
Port Channel
interface Port-channel3
description Port-Channel UCS
switchport trunk allowed vlan 1
switchport mode trunk
interface GigabitEthernet2/0/1
description Conexion UCS 1
channel-group 3 mode on
spanning-tree portfast trunk
interface GigabitEthernet2/0/2
spanning-tree portfast trunk Port Channel
3.- Can you post "show network eth0" from CUCM CLI?
TIA
Cristian.
Could you share this outputs from the switch?
show etherchannel summary
show etherchannel detail
show interface trunk
best regards
Dear Arturo
Datacenter#show etherchannel summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
3      Po3(SU)          -        Gi2/0/1(s)  Gi2/0/2(P)
Datacenter#show etherchannel detail
                Channel-group listing:
Group: 3
Group state = L2
Ports: 2   Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol:    -
                Ports in the group:
Port: Gi2/0/1
Port state    = Up Cnt-bndl Suspend Not-in-Bndl
Channel group = 3           Mode = On/FEC          Gcchange = -
Port-channel  = null        GC   =   -             Pseudo port-channel = Po3
Port index    = 0           Load = 0x00            Protocol =    -
Age of the port in the current state: 08d:01h:56m:20s
Probable reason: trunk mode of Gi2/0/1 is dynamic, Gi2/0/2 is trunk
Port: Gi2/0/2
Port state    = Up Mstr In-Bndl
Port-channel  = Po3         GC   =   -             Pseudo port-channel = Po3
Age of the port in the current state: 06d:21h:36m:37s
                 Port-channels in the group:
Port-channel: Po3
Age of the Port-channel   = 49d:17h:02m:47s
Logical slot/port   = 10/3          Number of ports = 1
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =    -
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi2/0/2  On/FEC             0
Time since last port bundled:    06d:21h:36m:47s    Gi2/0/2
Time since last port Un-bundled: 06d:21h:54m:42s    Gi2/0/2
Datacenter#
Datacenter#show interface trunk
Port        Mode         Encapsulation  Status        Native vlan
Po3         on           802.1q         trunking      1
Port        Vlans allowed on trunk
Po3         1
Port        Vlans allowed and active in management domain
Po3         1
Port        Vlans in spanning tree forwarding state and not pruned
Po3         1
Datacenter#
TIA
Cristian
and in the CUCM , but I can´t to reach the default gateway.
TIA
Cristian
Wild guess, but have you tried updating VMWare Tools? There might be something funky with the virtual network interface.
Dear All
I solved the problem. No vlan in the switch and in the VMWare.
Cristian.
Right, I never use any VLANs in ESXi as per my inital post and it has always worked well.
Chris
But the documentation say to use VLAN.
Thanks for you support.
Cristian
Have you looked at the switch logs for any errors? I had a customer deployment using C210s and found that one of the port-channel ports was in the (s) suspend state, this was due to flow-control enabled on the interface, this was evident from the logs.
Allan.
