Network Traffic Generator
adimaden001
Hi all
Could anyone suggest me a good Network Traffic Generator software (Free ofcourse or cheap ones) in windows platform? I am trying to setup a network where I can test and analyse the issues with VoIP packets under heavy traffic conditions. Please suggest!! I am struggling to find one. Thanks.
6 Replies 6
islam.kamal
Level 10
Level 10
Hi ADITYA
Can you find the below?.
1- For traffic generation Windows is pretty bad, especially UDP traffic  at any decent rates.
2-I would recommend the IP SLA feature in IOS to simulate VoIP and the statistics it generates are very good.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t4/htrtpvip.html
3- You can also check the following also :
https://www.netiq.com/products/unified-communications-and-voip-management/features/vivinet-assessor.html
please rate all useful information
adimaden001
Thank you kamal...I will check it
Sean K
You can also try SIPp (http://sipp.sourceforge.net/). I've just started using it and it seems a capable tool, but it's fairly complex...
Carl Ratcliffe
Level 3
Level 3
I use iperf which can be used to generate traffic. You can specify settings like tcp or udp, packet size, time etc.
It's a simple tool that is run on a source windows machine as a client and the destination windows machine as the server and you simply send traffic between the 2.
Thanks, Carl Ratcliffe
Sent from Cisco Technical Support Android App
Thank you Carl. I will chect it
Hi Cal,
Is there 64-bit version of iperf? I couldnt manage to find one, only 32-bit.
