new 200 lines
CSCO11328190
  Dears ,
          I received from service provider  ONE Access 1424  device for new 200 lines  , i want to connect
       this device to working network . I have 2801 gateway and CUCM 6.1 server connected to Multilayer switch
      4500 series .
          Please  i need the steps or links to connect this device .
Best Regards ,
paolo bevilacqua
Since that is not a Cisco product, why are you asking here ?
  Dear ,
   The configuration for this device it is from service provider . But how can i connect this device to
the voice gateway 2801 and CUCM 6.1 , and what the configuration can i configure in voice gateway
and CUCM 6.1. Service provider  give the device with SIP trunk configuration .
BestRegards ,
Hassan,
unsure what that 1424 device is, but you will have to work with your provider to build either:
a-a SIP Trunk from CUCM to the 1424
b:a SIP dial peer from your Cisco 2800 to the 1424 (and subsequently a pattern from your CUCM to your 2800)
I assume your provider gave you details on how to configure it in terms of authentication and IP address?!
R.,
Please remember to rate useful posts, by clicking on the stars below.
  Dears,
     Please can you tell me the steps for basic SIP thrunk configuration on to
the 2801 router  and CUCM 6.1 .
   or any links for this .  Thanks
BestRegards ,
