12-11-2017 08:08 PM - edited 03-17-2019 11:46 AM
Hello Everyone,
I got the new range of DID from ISP. I need to live that PRI on my exist PRI link. DID range started fro 2262787200 to 7399. We will not use of ext of these DID, I need to activate 02262787272 and 02262787373 on VG1 and VG2. From this PRI, i need to do voice routiing onn VG1 and VG2.
How should i do that and also let me know what chnages i need to do on CUCM.
Do i need to create Translation patter, Route-group,Route-list and route-pattern. On exist PRI link SIP is configured.
Please help me about to acheive this. Exist Config is attached for your refrence.
Viru.
Solved! Go to Solution.
12-13-2017 08:46 PM
Hi Viru,
I think you want to modify the call routing for enabling the incoming calls with the new DID number. Am I correct? As from your existing configuration in VGs, your carrier should sending 4 digits to your VG. If they do the same thing for the new range, you just need to add two more dial-peer with similar to your existing dial-peer 136147 & 136148. For example:
dial-peer voice 136145 voip
destination-pattern 7...
session protocol sipv2
session target ipv4:x.x.x.x
voice-class sip rel1xx require "100rel"
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 136146 voip
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
If you really want to limit only 7272 & 7373 from VGs to CUCMs, you need to create 4 dial-peer by renaming appropriate dial-peer number and change the pattern "7..." to "7272" & "7273". Remind you that double check whether you have another dial-peer which use the same number of my example.
Ben
12-11-2017 08:52 PM
12-13-2017 08:46 PM
Hi Viru,
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
Ben
