01-08-2018 03:21 PM - last edited on 03-25-2019 08:44 PM by ciscomoderator
After installing new cluster, i get the message below after a reboot.
Probing EDD (edd=off to disable)... ok
Any ideas?
Solved! Go to Solution.
08-07-2019 07:48 AM
This worked for my botched CUC 11.5 SU5 after a reboot did a vmware tools upgrade and failed. I was missing the script in my active partition, copying all files over (including the script) to the active and running it after chrooting fixed my no-boot. Thanks!
11-15-2018 09:22 PM
11-21-2018 06:05 PM
04-24-2019 05:54 AM
Worked in my case this morning. Finding in 12.1 also.
04-24-2019 08:37 AM
I think this is now a permanent "issue". I wish Cisco would remove the automatically check and upgrade selection from their OVA files.
02-01-2020 02:36 AM
This solved quickly the same issue for me in 11.5, thanks!
I disable the auto update method and did it manually, safer due to this bug.
