5133
Highlighted
Beginner
New Install CUCM 12.0
After installing new cluster, i get the message below after a reboot.
Probing EDD (edd=off to disable)... ok
Any ideas?
Steve
Please rate all helpful posts.
20 REPLIES 20
Highlighted
This worked for my botched CUC 11.5 SU5 after a reboot did a vmware tools upgrade and failed. I was missing the script in my active partition, copying all files over (including the script) to the active and running it after chrooting fixed my no-boot. Thanks!
Highlighted
Ruud, thank you kindly for sharing - saved me a cluster reinstall :-)
Highlighted
Where's this file in 10.5.2?
Highlighted
Worked in my case this morning.  Finding in 12.1 also.
Highlighted
I think this is now a permanent "issue". I wish Cisco would remove the automatically check and upgrade selection from their OVA files.
Highlighted
This solved quickly the same issue for me in 11.5, thanks!
I disable the auto update method and did it manually, safer due to this bug.
