11-02-2010 08:04 AM - edited 03-16-2019 01:41 AM
I’m working for one Voice project and would like to ask some technical questions. Please kindly advice if you have any ideas.
We have two offices, A and B.
A is like a HQ and using CUCM 8 with ISDN 10.
B is a branch office and they are using normal PABX Phone system (like Panasonic). They have 5 analog phone lines. They are using key system.
Customer wants us to implement office B as a part of office A, main office. Here’re my questions that I’m not quite clear.
Your additional comments and advices would be really appreciated.
Thank you All !
Sincerely,
Andrew
Solved! Go to Solution.
11-02-2010 01:56 PM
Hi Andrew,
Your best place to start with these type of Design questions is likely with
the CUCM SRND. The Deployment Model section below should answer your
questions
Multisite with Centralized Call Processing
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/models.html#wp1043616
Here we go;
Hope this helps get you started!
Cheers!
Rob
11-02-2010 01:56 PM
Hi Andrew,
questions
Here we go;
Cheers!
Rob
11-03-2010 09:50 PM
Hi Rob,
That's really helpful and I'm now running that project.
Many Thanks!
Andrew
"Welcome any comments from you guys"
11-08-2010 08:33 PM
Hi Rob,
This will be my very first CUCM project but I had experience on CUCME and CUE.
When I study CIPT1, there are much difference between CUCME and CUCM.
Could you please guide/share me some basic configuration about how to configure CUCM Business Edition?
Very much appreciate your help!
Sincerely,
Andrew
11-09-2010 05:27 AM
Hi Andrew,
It's great that you already have some good knowledge here
Like you nicely noted, CUCM-BE is completely different than CME
and CUE but some of the concepts will carry across quite well. Here are
some excellent new guides;
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/cucmbe_task_list/8xcucmbetask.html
Installing Cisco Unified Communications Manager Business Edition Release 8.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/install/8_0_1/cmins801.html
Cisco Unified Communications Manager Administration Guide for Cisco Unified Communications Manager Business Edition, Release 8.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/admin/8_0_1/ccmcfg/bccm-801-be.html
Have a look through these to get some general ideas for "getting started"
Cheers!
Rob
11-09-2010 06:44 AM
Many Thanks Rob!
Cheer,
Andrew
