New SIP 12.7(1) Firmware
dp215
Has anyone experienced any issues with the new firmware for the 88XX models?
On incoming calls the caller id displays the Called Party DN instead of the Calling Party DN. If I downgrade to 12.6 everything works as normal. We're running 11.5 SU7
George Sotiropoulos
Unfortunately I haven't tested it yet, you may check the following 2 links for any open caveats:
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Thanks for the response George. I did check the caveats.
