05-15-2013 11:25 PM - edited 03-16-2019 05:20 PM
Dear All
What's different between product as NEW-UWL-STD and CUWL-ADDON-STDK9 , Does NEW-UWL-STD can replace to L-CUWL-ADDON-STDK9 ?
05-16-2013 03:43 AM
NEW is the first order of a new install. ADDON is additional licenses for an existing install. The ordering guides (partners only) cover this in detail.
Please remember to rate helpful responses and identify helpful or correct answers.
07-08-2019 01:27 AM
What is major part code of this PID I unable to locate it on CCW?
I can see NEW-CUWL only are these part code are same?
Thank you.
07-08-2019 03:07 AM
Start with the top level part CUWL-11X-K9 or CUWL-12X-K9. Somewhere in the options under Order Type you select whether it's New, Add On or Upgrade.
07-29-2020 03:52 AM
The customer has CUWL Professional (11.x) and CUWL Standard (11.x)
How do we renew the subscription of this and customer hasn't given any PAK.
in CCW-R, it doesn't allow me to add the below
NEW-UWL-11X-STD
NEW-UWL-11X-MTG
how do i renew the subscription of above,
Please help
@TONY SMITH wrote:Start with the top level part CUWL-11X-K9 or CUWL-12X-K9. Somewhere in the options under Order Type you select whether it's New, Add On or Upgrade.
07-29-2020 04:25 AM
07-29-2020 04:57 AM
To renew, the easiest way in CCW-R is to select the contract, then generate renewal from there. I think that's really the only correct way, it preserves instance numbers and shows unbroken coverage. If for some reason you can't do that then you'll need to identify the correct service parts (for example for CUWL Standard it is "LIC-UWL-STD-A"). You also need to be prepared in case Cisco chooses to audit, you would need to show existing cover extending up to the start date of your new quote.
If the existing contract is no longer Active or Overdue, then it can't be renewed.
07-29-2020 05:40 AM
Many Thanks,
I have one more query
Customer had CUWL Professional (11.x) which is now EOS and cannot be renewed
Does he really need to buy Meetings ( repalcement for CUWL Pro) with License and support or shall they just buy support of Meetings and do the upgrade from PRO to meetings
As number of users is more, buying meetings with license will turn out to be very expensive
07-29-2020 10:00 AM
@GK1 wrote:Many Thanks,
This thread is getting mixed up with different people joining it to ask unrelated questions, instead of starting their own discussion. However if you're talking about renewal of an existing Active or Overdue contract then please confirm this. Otherwise we're all going to be at cross purposes.
07-29-2020 03:54 AM
NEW-UWL-11X-STD
NEW-UWL-11X-MTG
Please help
08-04-2020 12:12 PM
To renew the SWSS, you need either PAK,SO or Instance Number. if you cannot find these from customer, contact local Cisco. SE could be able to provide it.
07-29-2020 05:41 AM
08-04-2020 12:20 PM
This part number has reached end of life not EOS. you can to go with Upgrade part number or open up a case with customer support or Cisco licensing and check if they can convert it to meeting.
