newbie guide
jonathang
Anyone recommend a step by step guide for unity.
Need to
Setup call groups
Hunt groups
Etc
Anas Abueideh
Level 9
Level 9
the below book is really helpful
http://www.ciscopress.com/store/cisco-unity-connection-9781587142819
Anas
please rate if it is helpful
Jaime Valencia
Some if what you're asking is CUCM, not Unity. There are really no step by step guides, anyhow, its pretty straightforward. Get into the server and you can use the help -> for this page assistance
java
if this helps, please rate
Thanks all :-)
