05-14-2013 07:40 AM - edited 03-16-2019 05:18 PM
We have an office that wants to be able to leave greetings for callers but doesn't want the caller to be able to leave messages.
How do I do this?
Thank you!
05-14-2013 07:41 AM
Hi Brett,
What voicemail system are you running?
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
05-14-2013 07:46 AM
Unity Connection. We have only had this Cisco system for 2 weeks and I have alot to learn.
05-14-2013 08:16 AM
Hi Brett,
No worries my friend, we all have alot to learn but
that's what makes CSC so great
There are a couple of ways to do this;
You can change the "After Greeting" action on the user Greeting page to either
Hang-up or Say Goodbye.
You can get the users to record their Alternate Greeting and then set the "Block Messages"
on the user greeting when Alternate Greeting is recorded.
Cheers!
Rob
"Talk about a dream
- Springsteen
05-14-2013 08:27 AM
I'm glad I hit refresh before I posted my reply! Plus 5 should always go to Rob!
I'll add my tuppence worths to Rob's reply:
You will want to eventually set up a call handler to do this for you, simply because a user vm box consumes a license and a call handler doesn't.
Gareth
05-14-2013 08:44 AM
Thank you Rob! Worked perfectly!
05-14-2013 08:39 AM
Hey Gareth,
Thanks for the kind words my friend & +5 back at ya!
Yes, as you nicely noted, saving $$$ is always a great plan
Cheers!
Rob
"Talk about a dream
- Springsteen
05-14-2013 09:03 AM
Hi Brett,
You are most welcome my friend! Happy posting
Cheers!
Rob
"Talk about a dream
- Springsteen
