Community Helping Community
306
Highlighted
Beginner
NGN configuration at CME
Hello Friends,
I am having trouble to configure my CME router to work with a NGN number that the carrier provided me to use.
See dial-peer below:
CME_ISRG2#show run | begin dial-peer
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 10 voip
incoming called-number .
voice-class codec 2
dtmf-relay h245-alphanumeric
dial-peer voice 5 voip
destination-pattern 4.......
session protocol sipv2
session target ipv4:192.168.0.5
voice-class codec 2
dial-peer voice 104 pots
shutdown
destination-pattern 21011577
port 0/0/0
forward-digits 0
dial-peer voice 100 voip
destination-pattern 0........
session target sip-server
gateway
timer receive-rtp 1200
sip-ua
sip-server ipv4:172.18.100.110
Please, help?
Alan.
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Mentor
Alan,
What is th eproblem you are having..
This dial-peer configuration seems suspect!
shutdown
port 0/0/0
forward-digits 0 (this command strips off all digit) Why do you have it?
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
2 REPLIES 2
VIP Mentor
Alan,
shutdown
port 0/0/0
Beginner
Hello aokanlawon,
You was right there was no need to use the forward-digits 0.
Today I worked hard with a Cisco engineer and now it seems that we finish.  We deleted the old one and created this dial-peer:
dial-peer voice 56 pots
destination-pattern 2121011577
progress_ind setup enable 3
direct-inward-dial
port 0/0/0
But the calls from NGN was not proceding. And then we realized that was a timer issue with min-se, see below the command that resolved:
voice service voip
sip
  min-se 90
  no call service stop
And after all, the ring back was not being sent when connections come from NGN...
The progress_ind setup enable 3 resolved this one.
Sorry for don't back you early.. And thank you for the all useful replies!
Content for Community-Ad
FusionCharts will render here
