02-05-2009 08:17 AM - edited 03-15-2019 04:01 PM
How is NIC teaming enabled on UCM 6.1 servers. I thought it was via the "set network failover" command but I am not able to get this working
02-05-2009 08:23 AM
It is indeed. The full command is:
set network failover enable
02-16-2009 09:55 AM
Is NIC teaming is supported on Call manager 6.1.2 (IBM platform)
02-16-2009 10:02 AM
Hi Asim,
NIC Teaming Support
Server platforms with dual Ethernet network interface cards (NICs) can support NIC teaming for network fault tolerance with Cisco Unified Communications Manager. Cisco began support of NIC teaming on HP servers in the 5.0(1) release and began support on IBM servers in the 6.1(2) release. This feature allows a server to be connected to the Ethernet via two NICs and, hence, two cables. NIC teaming prevents network downtime by transferring the workload from the failed port to the working port. NIC teaming cannot be used for load balancing or increasing the interface speed.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412614
Hope this helps!
Rob
02-16-2009 10:10 AM
Thanks rob,
Can you give me sample configuration for enabling Teaming on cisco Call manager 6.1.2(IBM)
thanks in advance
02-16-2009 10:17 AM
It's the same command listed above.
