NICE and Call Manager integration
SJ SJ
Did anyone successfully integrate cisco call manager 4.3 with NICE recording system. What were the steps taken for integration.
Regards.
5 Replies 5
paolo bevilacqua
On CM, nothing.
On the switch, span voice gateway port to voice recorder server port .
Voice recorder configured as per vendor documentaion.
Paolo,
I said the same to the NICE vendor. But the vendor says that they need to integrate it with the call manager to get call details.
Integrate what?
If they don't know what they have to do, change vendor.
Tapan Dutt
HI
Also I have attached a Document which is from NICE.
Tapan
Hello i have the same issue, how did you solve?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
