NIM-2FXS/4FXO module is FXS and FXO active at the same time?
samhopealpha
Hi everybody,
A quick question, is there any document mentioned about the Fourth-Generation Voice NIM module >>> NIM-2FXS/4FXO
all 6 ports are active at the same time? or if 2FXS is active, then 4FXO should be inactive?
Thank you
Sam
acampbell
If you are having issues with this module have a read at this link
https://www.cisco.com/c/en/us/support/docs/field-notices/643/fn64321.html
May be you are being hit with that issue..
Regards, Alex. Please rate useful posts.
