Highlighted
Participant
NIM card: how to determine slot and subslot for command card type e1 ?
We have new installation for PRI line. we have ISR4321 router and NIM-2MFT-T1/E1 - T1/E1 Serial Module with PVDM 64 installed.
Router#sho inventory
NAME: "Chassis", DESCR: "Cisco ISR4321 Chassis"
PID: ISR4321/K9        , VID: V04, SN: FDO2225A2QT
NAME: "Power Supply Module 0", DESCR: "110W AC Power Supply for Cisco ISR 4320"
PID: PWR-4320-AC       , VID:    , SN:
NAME: "Fan Tray", DESCR: "Cisco ISR4320 Fan Assembly"
PID: ACS-4320-FANASSY  , VID:    , SN:
NAME: "module 0", DESCR: "Cisco ISR4321 Built-In NIM controller"
PID: ISR4321/K9        , VID:    , SN:
NAME: "NIM subslot 0/2", DESCR: "NIM-2MFT-T1/E1 - T1/E1 Serial Module"
PID: NIM-2MFT-T1/E1    , VID: V05, SN: FOC222339CG
NAME: "subslot 0/2 db module 0", DESCR: "PVDM4-64 Voice DSP Module"
PID: PVDM4-64          , VID: V02, SN: FOC222314YE
NAME: "NIM subslot 0/0", DESCR: "Front Panel 2 ports Gigabitethernet Module"
PID: ISR4321-2x1GE     , VID: V01, SN: JAB092709EL
NAME: "module R0", DESCR: "Cisco ISR4321 Route Processor"
PID: ISR4321/K9        , VID: V04, SN: FDO22241V8Y
NAME: "module F0", DESCR: "Cisco ISR4321 Forwarding Processor"
While configuring on router how we will determine card type e1 command? ie slot and subslot?
can some body explain it?  from the above inventory how will i determine slot and subslot?
3 REPLIES 3
Highlighted
Participant
Re: NIM card: how to determine slot and subslot for command card type e1 ?
yes i got it.
this is what we need to check
so command will be
card type e1 0 2
Highlighted
Hall of Fame Master
That is correct.
Highlighted
Advisor
you can also refer the below link with Table 1.6 for details
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/Overview.html#32890
regds,
aman
