AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
181
Beginner
No Audio CME
PRI connected to CME
CME configured as H.323 gateway in CUCM
CME configured with VOIP dial peer point to CUCM
4 REPLIES 4
Participant
Re: No Audio CME
Share router config
Please remember to rate useful posts, click on the stars below.
Re: No Audio CME
We will also need these debugs to understand whether the h245 negotiation is completing successfully between the gateway and the CUCM.
debug h225 asn1
debug h245 asn1
debug cch323 h225
debug cch323 h245
Please also check if there are any firewalls between the gateway and the CUCM/destination phone that could be dropping RTP packets.
Re: No Audio CME
If you have a SIP CME running an H.323 network to CUCM, that is NOT supported. If it is SCCP CME, you should be good.
Do a "show voip rtp connection" and ensure the local IP can reach the remote IP which should be the CME IP and phone IP on CUCM respectively taken the fact that a media resource is not being invoked.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Beginner
Re: No Audio CME
Sorry for the late reply respected members, the issue has been resolved after removing and re-configuring the gateway.
Content for Community-Ad
August's Community Spotlight Awards
