NO AUDIO FOR SPECIFIC NUMBERS
ainaraza1
Hello;
        I am unable to hear audio whenever I dial U.S Numbers however every calls work fine except a single number which is also mentioned in debugs. I 've tried the same with ISDN PRI and the call works absolutely fine with no problems
        SIP TRUNK (alaw)   SIP TRUNK (alaw)
ITSP ----------------->CUBE -------------------> CUCM --------------------> IP PHONE
Debugs are attached and any help will be highly appreciated.
Jonathan Els
Level 5
Level 5
This is a duplicate of https://supportforums.cisco.com/discussion/12875506/no-audio-specific-numbers.
