Walkthrough Wednesdays
252
angel-moon
Participant
No BAT Option
Hello,  I'm new to an environment.  WHen I log onto the CM Admin page I am not seeing the "Bulk Administration" option usually right beside User Management.  Any idea on where to look forst to fix this?  I am logged in as an Admin.
Thanks in advance.
Replies rated!
1 ACCEPTED SOLUTION
Mike_Brezicky
If the service is running, are you logged into the PUB or SUB? Pretty sure BAT menu only shows when logging into the PUB.
3 REPLIES 3
Jaime Valencia
Hall of Fame Cisco Employee
Is the service running?
java
if this helps, please rate
piyush aghera
Enthusiast
Navigate to Cisco Unified Serviceability -> Tools -> Control Centre Feature Services
Select your publisher
Look for service Cisco Bulk Provisioning Service is running or not.
I assume it is not running and hence you are not getting Bulk Administration options.
Mike_Brezicky
Content for Community-Ad
Spotlight Awards 2021
