04-15-2011 07:58 AM - edited 03-16-2019 04:32 AM
When I call from PSTN to a Cisco IP Phone and the IP Phone has an active call, no busy tone is played, instead there is a normal alerting. The busy trigger in CUCM is set to 1.
Here is a debug isdn q931 output of the h323 gateway:
Voice_GW_LABOR_BE(config-dial-peer)#
*Apr 15 14:31:28.531: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x0183, '0123456789'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '9942152'
*Apr 15 14:31:28.551: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
*Apr 15 14:31:29.551: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
*Apr 15 14:31:29.567: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x8091 - User busy
*Apr 15 14:31:29.671: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
*Apr 15 14:31:29.675: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
*Apr 15 14:31:42.211: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
Cause i = 0x8090 - Normal call clearing
*Apr 15 14:31:42.219: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
Interesting is, that the gateway is sending a disconnect to the ISDN Switch.
Here is the relevant config:
network-clock-participate wic 0
isdn switch-type basic-net3
isdn voice-call-failure 0
voice call convert-discpi-to-prog
no voice call carrier capacity active
voice rtp send-recv
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
call preserve
voice-card 0
dsp services dspfarm
interface FastEthernet0/0
ip address 10.145.220.6 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.145.220.6
interface BRI0/1/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
no isdn outgoing display-ie
no isdn outgoing ie caller-number
isdn static-tei 0
voice-port 0/1/0
compand-type a-law
cptone CH
bearer-cap Speech
dial-peer voice 1 voip
destination-pattern 994215.
voice-class codec 1
voice-class h323 1
session target ipv4:10.145.220.40
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 20 pots
preference 1
max-conn 1
destination-pattern 0T
progress_ind alert enable 8
progress_ind progress enable 8
incoming called-number .T
supplementary-service pass-through
direct-inward-dial
port 0/1/0
Cheers
Peter
04-17-2011 05:27 AM
Router is correctly telling telco that user is busy:
Since no "inband tone" IE is present, it is telco responsability to play busy tones to caller, not the router.
Alos, telco switch seems to be further misbehaving in that it sends "release" two more times after router has correcly ended the call with "release complete".
