No busy tone from Siemens PBX behind MGCP Gateway
we have the following scenario:
PSTN --- MGCP --->QSIG--->SIEMENS HiPath 4000
CUCM Version: 9
IOS Version: 15.2.4
When a Siemens phone is busy, and a PSTN call arrives we get an "inband information" and  "Cause= User Busy" back from Siemens on the qsig trunk and also send this "inband" busy back to PSTN, but the PSTN caller does not hear anything. So the busy tone is missing.
Within Siemens, everything works fine. Also between Siemens and Cisco. Also when a Cisco phone is busy a PSTN caller hear the busy tone. The only difference I see, is that the Siemens send us an inband information, and when a CUCM Phone is busy we have no inband information.
What can we do?  Does anyone faces the same issue?
Christian
Try to see this similar post:
https://supportforums.cisco.com/thread/2077303
Regards.
Hi Christian,
can I ask you if you have find a solution for the problem "No busy tone from Siemens PBX behind MGCP Gateway" ?
We have a similar problem...
Thanks in advance,
Santino
Hi Santino,
we have a similar problem ; did you solve it.
Thanks in advance
Roberto
