Highlighted
Beginner
Can you specify this more in
Can you specify this more in detail?
Contributor
If you configure a SIP trunk
If you configure a SIP trunk between the CUCM and the gateway instead of H.323 the issue (the TAC engineer never opened a bug for this!) is probably gone. We haven't seen the issue with 10.5(2)SU1 and a SIP trunk with an annunciator to the gateway.
Stefan
Beginner
Ah ok, thank you for the
Ah ok, thank you for the description. We will see if we will can migrate to a SIP trunk.
Content for Community-Ad
August's Community Spotlight Awards
