No Call Handler Input (CUC) digit accept from outside call problem
mehrdadelectron
Hi friends,
we have Cisco Unity for transfer calls (Call handler) beside CUCM, when we call Unity extension(1001) with internal ip phone(like 2002) greeting will play & call input works fine(for example transfer to 2001 extension [B]) but when make call from outside like PSTN or Mobile [A],the greeting will play but ignore any input digit or extension that dialed.do you know what is the problem?
,Best regards
mehrdad
Try adding
dtmf-relay h245-alphanumeric
On your dial-peer voice 1008
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
5 Replies 5
Aaron Harrison
Probably an incorrect setup on your VG> What is that? MGCP? CUBE? Other?
Can you post the config?
Aaron
we have e1 link with 30 lines & simple H.323 config on VG to reach the number 1001 but i should mention the number with area code is 8887771001 & I used translation in CUCM to convert the number to 1001. the ip address (192.168.1.100) is for CUCM.
voice-port 0/0/0:15
no vad
local-alerting
no comfort-noise
bearer-cap Speech
dial-peer voice 1008 voip
destination-pattern 8887771001
session target ipv4:192.168.1.100
dial-peer voice 1009 pots
incoming called-number 8887771001
direct-inward-dial
Try adding
Aaron
Thanks for your fast reply.
that s worked!
Ahmed Zaki189
hello, I Have same problem
There are a set of 180 sip trunk DIDs 22056xxx and 22060xxx were subscribed, On these DID ranges it is noticed that when PSTN calls come on the line and attended by the cisco unity, when the caller dials the internal extension. the call rings 1 sec and then disconnects.
Call 22056XXX ----> For ( Arabic press 1 - English Press 2 ) -----> After that choice option from 1 to 9 ( when press any number from list or even press internal Ext number other side receive call and ringing for only 1 sec and call cancel.
Otherwise, when set the DID number direct to internal number by ( Translation Pattern & Transformation Pattern ) working fine without any problem, only the two DID number going to Cisco Unity make this problem.
Please find the attached Trace ( 172.30.4.33 is the CUBE router )
