01-02-2013 11:53 AM - edited 03-16-2019 02:57 PM
We recently upgraded the software pack on a UC520 to 8.6.0 to support a 7962.
We have the phone registered and can take a receive calls. But it can only take and receive 1 call at a time. All other calls go straight to VM. I have it set to a Dual Line and configured pretty much the same as the other users but its just this extension. Even stranger is that it takes a good 30 seconds when one call is ended for the line to be seen as free and another call can then come in.
Also this user cannot pickup call parks for some odd reason.
I can post the config if needed.
Thoughts?
Jason Ryan
Edit: Relevant data uploaded. Problem Ephone is Ephone 9. Some names and IP removed.
01-02-2013 11:59 AM
Kindly post the config.
Yosh
01-02-2013 01:11 PM
Hi Jason,
I'm guessing the "single" call issue is related to the "Headset Auto-Answer" setting
Cheers!
Rob
"Far away from your trouble and worry
You belong somewhere you feel free" - Tom Petty
01-02-2013 01:32 PM
I had actually disabled the whole ehook feature to test that and it was still occurring. Thoughts?
01-02-2013 02:02 PM
Hi Jason,
I was referring to this portion of the config;
ephone 9
no multicast-moh
device-security-mode none
headset auto-answer line 1
mac-address 88F0.7789.C305
ephone-template 16
max-calls-per-button 2
username "XXX XXX" password 123456
speed-dial 1 913052516124 label "XXX XXX"
paging-dn 100
type 7962
button 1:9 2o75,76
Cheers!
Rob
01-02-2013 02:27 PM
I went ahead and removed that line. I also was having some MAC Address conflicts so I remade the Ephone just like above but without the line.
The phone still cannot pick up parked calls.
01-02-2013 02:47 PM
Now I actually just noticed this. In my DNs I have 2 correspdoning to the same extension. I have the example below.
ephone-dn 224 dual-line
number 6407 no-reg primary
label 6407
description 3373216407
name xxxx
call-forward busy 5000
call-forward noan 5000 timeout 20
ephone-dn 9 dual-line
number 6407
label 6407
name xxxx call-forward busy 5000
corlist incoming user900-international
night-service bell
The dn 9 should be the right one. Could this duplicate be causing this issue?
01-04-2013 07:53 AM
It looks like the MAC Address duplication issue was definitely the issue. I had given the user a new 7962 as opposed to a 524. The ephone was holding onto the 524 causing all kinds of headaches.
Recreated the ephones and it worked well.
01-04-2013 08:45 AM
Hey Jason,
Nice work my friend! +5 for this very kind follow-up
Cheers!
Rob
