No Caller ID sent to Outside
Eugen Bitca
From debug isdn q931 what means the following:
        Cause i = 0x80E46C - Invalid information element contents
        Call State i = 0x06
When I call outside, the calling number is not transmitted.
10 Replies 10
Ayodeji Okanlawon
Eugen,
This cause code  Cause i = 0x80E46C - Invalid information element contents, means that you are sending information element not understood by the far end switch. It can also mean you are trying to place a call using network number when  your provider  only accept National, International or Unknown dialling.
Can you send the full debug isdn q931. Let me know the called and calling number
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
full debug isdn q931:
Jun 29 14:51:33.480 EEST: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 812467
Jun 29 14:51:33.484 EEST: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x31A6 callID = 0xB059 switch = primary-net5 interface = Network
Jun 29 14:51:33.484 EEST: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x31A6
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18382
                Preferred, Channel 2
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Display i = 'MCC'
        Calling Party Number i = 0x2182, '812467'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '9022256499'
Jun 29 14:51:33.532 EEST: ISDN Se0/1/0:15 Q931: RX <- STATUS pd = 8  callref = 0xB1A6
        Call State i = 0x06
Jun 29 14:51:33.556 EEST: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xB1A6
Jun 29 14:51:34.908 EEST: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x08BB
                Standard = CCITT
        Calling Party Number i = 0x80, '022812599'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '499'
        High Layer Compat i = 0x9181
        Sending Complete
Jun 29 14:51:34.912 EEST: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0x88BB callID = 0x1DFD switch = primary-net5 interface = Network
Jun 29 14:51:34.916 EEST: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xB1A6
Jun 29 14:51:34.928 EEST: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x88BB
        Channel ID i = 0xA98383
                Exclusive, Channel 3
Jun 29 14:51:34.940 EEST: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x88BB
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Jun 29 14:51:35.548 EEST: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xB1A6
Jun 29 14:51:35.548: %ISDN-6-CONNECT: Interface Serial0/1/0:1 is now connected to 9022256499 N/A
Jun 29 14:51:35.552 EEST: ISDN Se0/1/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x31A6
Jun 29 14:51:36.236: %ISDN-6-CONNECT: Interface Serial0/1/0:1 is now connected to 9022256499 N/A
Here is the trace...(i belive this is the correct call)??
Looks like your provider wants plan uknown, type unknown, from the trace for an incoming call. Your provider is sending plan: unknown, type unknow.
Try and add this commad to your interfaxe se0/1/0:15
isdn map address ^9* plan unknown type unknown
Test again and send debug isdn q931. The command above ensure that any number through the interface that begins with 9 will use plan:unknown  type:unknown
Jun 29 18:21:34.524 EEST: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 022812467
Jun 29 18:21:34.524 EEST: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x31F1 callID = 0xB0A4 switch = primary-net5 interface = Network
Jun 29 18:21:34.524 EEST: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x31F1
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Display i = 'MCC'
        Calling Party Number i = 0x0082, '022812467'
        Called Party Number i = 0x80, '9022256499'
Jun 29 18:21:34.576 EEST: ISDN Se0/1/0:15 Q931: RX <- STATUS pd = 8  callref = 0xB1F1
        Call State i = 0x06
Jun 29 18:21:34.600 EEST: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xB1F1
mobiasBK-R1#
Jun 29 18:21:35.852 EEST: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xB1F1
Jun 29 18:21:36.468 EEST: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x30BC
                Standard = CCITT
        Sending Complete
Jun 29 18:21:36.472 EEST: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0xB0BC callID = 0x1EA5 switch = primary-net5 interface = Network
Jun 29 18:21:36.484 EEST: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xB0BC
        Channel ID i = 0xA98382
                Exclusive, Channel 2
Jun 29 18:21:36.492 EEST: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xB0BC
Jun 29 18:21:37.108 EEST: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xB1F1
Jun 29 18:21:37.108: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 9022256499 N/A
What is this  "Display i = 'MCC'"  Looks like your provider doesnt like it too..
MCC - is the name recived from MediaCallCenter whre the phones reside.
How to clear it?
What is your setup? Can you describe it?
Eg..IP phone--->cucm----->vg----PSTN.
Can you send the sh run of your gateway
Can you also confirm what the DDI of your phones are. Is the calling number a DDI in your DDI range from provider
I confirm the calling number is from the provider range.
Bellow are 2 debugs,
First is from IP Hard Phone registered to Cisco CME, and the second is from Soft PHone Registered to MCC H323 GW Server.
un 30 09:06:29.088 EEST: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 812499
Jun 30 09:06:29.088 EEST: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x3209 callID = 0xB0BC switch = primary-net5 interface = Network
Jun 30 09:06:29.088 EEST: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3209
        Sending Complete
                Standard = CCITT
        Display i = 'Reception'
        Calling Party Number i = 0x0080, '812499'
        Called Party Number i = 0x80, '9022256318'
Jun 30 09:06:29.152 EEST: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xB209
Jun 30 09:06:30.348 EEST: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xB209
Jun 30 09:06:32.812 EEST: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x3209
        Cause i = 0x8290 - Normal call clearing
Jun 30 08:52:14.954 EEST: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 812467
Jun 30 08:52:14.954 EEST: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x3204 callID = 0xB0B7 switch = primary-net5 interface = Network
Jun 30 08:52:14.954 EEST: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3204
        Sending Complete
                Standard = CCITT
        Display i = 'MCC'
        Calling Party Number i = 0x0082, '812467'
Jun 30 08:52:15.006 EEST: ISDN Se0/1/0:15 Q931: RX <- STATUS pd = 8  callref = 0xB204
        Call State i = 0x06
Jun 30 08:52:15.026 EEST: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xB204
Jun 30 08:52:16.198 EEST: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xB204
Jun 30 08:52:22.630 EEST: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x3204
Configuration of the Cisco CME:
isdn switch-type primary-net5
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service pots
voice service voip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
h323
voice class codec 1
codec preference 1 g711ulaw bytes 160
voice iec syslog
voice cause-code
error-category 128 q850-cause 27
voice translation-rule 467
rule 15 /...467$/ /812467/
voice translation-profile mine_out
translate calling 467
voice-card 0
no dspfarm
controller E1 0/1/0
pri-group timeslots 1-31
interface Loopback0
ip address 172.16.1.1 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.1.1
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
isdn send-alerting
isdn negotiate-bchan resend-setup
isdn sending-complete
no cdp enable
voice-port 0/1/0:15
input gain -3
output attenuation 3
echo-cancel coverage 32
cptone RU
bearer-cap Speech
dial-peer voice 2 pots
description *** ANY"9" ***
destination-pattern 9.T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
no digit-strip
direct-inward-dial
port 0/1/0:15
forward-digits all
dial-peer voice 256467 voip
destination-pattern 467
voice-class codec 1
session target ipv4:10.44.1.1
dtmf-relay rtp-nte
no vad
dial-peer voice 4670 pots
translation-profile outgoing mine_out
progress_ind alert enable 8
incoming called-number ...467
no digit-strip
direct-inward-dial
port 0/1/0:15
forward-digits all
Also attached the ip telephony topology (CME.jpg)
from "debug voip ccapi inout":
SOFT_PHONE:
Call Params(Calling Number=812467,(Calling Name=MCC)(TON=National, NPI=ISDN, Screening=User, Failed, Presentation=Allowed),
   Called Number=9022256318(TON=National, NPI=ISDN), Calling Translated=FALSE,
HARD_PHONE:
Call Params(Calling Number=812499,(Calling Name=Reception)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=9022256318(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
What kind of Failed is that?
The h323 softphone has this "TON=National, NPI=ISDN". The hardphone has this "TON=Unknown, NPI=Unknown"
So try and change the parameter of the h323 phone to be similar to the hardphone. Sorry I dont know anythung about h323 phone and MCC servers
last questions,
what means:
and how to change Screening Indicator (cisco-anisi=)
THANKS
