05-25-2012 01:08 AM - edited 03-16-2019 11:20 AM
Hello everyone,
I'm testing a new voice connection to a SIP provider.
I've enabled the following:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
The sip-ua configuration is has follows:
sip-ua
credentials username XXXXX password YYYY realm sip.XXX.com
authentication username XXXXX password YYYY
registrar dns:sip.XXX.com expires 3600
sip-server dns:sip.XXX.com
From the "debug ccsip messages" i can see the Register request being sent and the 200 OK being received and running a "show sip-ua register status" i can see the XXXXX as registered.
The problem is, when i try to call a specific test number that i want to go out through this SIP provider, i don't see the INVITE packet being sent, altough in the "debug voice dialpeer" i can see the following dial-peer being matched:
dial-peer voice 11 voip
destination-pattern 123456789
session protocol sipv2
session target dns:sip.XXX.com
dtmf-relay sip-notify
codec transparent
no vad
Any idea why?
05-25-2012 01:14 AM
By the way:
Router 2911 running version 15.1
Telephony version 8.6
05-25-2012 02:39 AM
Can you try the ff:
Dial-peer voice 11 voip
Codec G711u
Can you send the output of your debug ccsip message here
05-25-2012 03:59 AM
The codec doesn't seem to be the issue here, since even the control info is not going through.
The problem is theres no output of the debug ccsip message, apart from the regular registration:
May 25 10:56:18.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.XXXXXX.com:5060 SIP/2.0
Via: SIP/2.0/UDP x.x.x.x:5060;branch=z9hG4bKBB21A47
To: <>>XXXXXXXXX@sip.XXX.com>
Date: Fri, 25 May 2012 10:56:18 GMT
Call-ID: A2F0AAE-A4F611E1-AFF5C3CC-899281C4
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1337943378
CSeq: 299 REGISTER
Contact:
Expires: 3600
Authorization: Digest username="XXXXXXXXXXXXXX",realm="sip.XXX.com",uri="sip:sip.XXX.com:5060",response="1599e81611c486f6d01a900d7582bc36",nonce="4fbf6513000110ce2eec642e242d5c49228d65a55be69b0e",algorithm=MD5
Content-Length: 0
May 25 10:56:18.666: //8366/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
From: <>>XXXXXXXXXXX@sip.XXX.com>;tag=3892FB54-21B4
To: <>>XXXXXXXXXXXX@sip.XXX.com>;tag=c97b4d1cb1f3d0da549e06a8d482ef63.ef3b
CSeq: 299 REGISTER
Via: SIP/2.0/UDP 172.26.12.253:5060;branch=z9hG4bKBB21A47
Contact:
Server: OpenSIPS
Expires: 300
Content-Length: 0
05-25-2012 02:51 AM
Can the router resolve the sesion-target sip.XXX.com?
05-25-2012 04:12 AM
yes.
And also with the session-target ipv4:x.x.x.x i still can't see the INVITE package, but the result is diferent. Instead of the call being dropped when i match the dial-peer, i get a fast busy signal.
05-25-2012 04:45 AM
Solved.
Aparently my translation-profile wasn't working properly, and i wasn't announcing the correct user to my sip provider. I was expecting that if this was the problem i should at least see a Unauthorized packet coming from my SIP provider but that wasn't the case.
After changing my dial-peer:
corlist outgoing Peer-Nacional
translation-profile outgoing Mask
codec g711ulaw
clid network-number XXXXXXX
no vad
Result:
May 25 11:37:39.330: //8511/DC5D325CB504/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:123456789@sip.XXX.com:5060 SIP/2.0
Via: SIP/2.0/UDP x.x.x.x:5060;branch=z9hG4bKBDA64B
From: "user" <>>XXXXXXXX@sip.XXX.com>;tag=38B8D6EC-959
To: <>>123456789@sip.XXX.com>
Date: Fri, 25 May 2012 11:37:39 GMT
Call-ID: DDAD8184-A59411E1-B509C3CC-899281C4@172.26.12.253
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3697095260-2777944545-3036988364-2308080068
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1337945859
Contact:
Call-Info:
Expires: 180
Allow-Events: telephone-event
Proxy-Authorization: Digest username="XXXXXXXXXX",realm="sip.XXX.com",uri="sip:123456789@sip.XXX.com:5060",response="6f162daec8974185533a8a5699f5c57d",nonce="4fbf6ec400000279262314bacddf71622194962790d7152f",algorithm=MD5
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 6922 6037 IN IP4 172.26.12.253
s=SIP Call
c=IN IP4 x.x.x.x
t=0 0
m=audio 17010 RTP/AVP 0
c=IN IP4 x.x.x.x
a=rtpmap:0 PCMU/8000
a=ptime:20
May 25 11:37:39.546: //8511/DC5D325CB504/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
May 25 11:37:42.394: //8511/DC5D325CB504/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
May 25 11:37:43.626: //8511/DC5D325CB504/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
v=0
o=CiscoSystemsSIP-GW-UserAgent 6922 6037 IN IP4 78.141.179.70
s=XXX call
c=IN IP4 78.141.179.70
t=0 0
m=audio 25872 RTP/AVP 0
a=rtpmap:0 pcmu/8000
a=ptime:20
05-25-2012 07:55 AM
First of all glad to see you have resolved it.
Secondly, I strongly believe that you had an issue with your codec (i may also be wrong but we can confirm that). As I can see you are now using my suggested codec. So i am at a loss why you were quick to dismiss that suggestion even though you are now using it.
It will be intresting to see if your call will proceed if you revert back to codec transparent as you had previuosly. Do you wnat to give that a go and let me know what the result is..
