ā03-25-2013 05:11 AM - edited ā03-16-2019 04:25 PM
hi,
i tried configuration cisco router 2811 (ucme 7.1) with x-lite,configuration is :
int fa0/0
no shut-->exit
voice service voip
allow-connections sip to sip
sip
registrar server expires max 1200 min 300voice register global
mode cme
source-address 192.168.1.1 port 5060
max-dn 10
max-pool 5
authenticate register
tftp-path flash
create profilevoice register dn 1
number 51234
allow watch
name voip
label 51234voice register pool 1
id mac DEAD.BEEF.0001 ( id mac PC1)
number 1 dn 1
dtmf-relay sip-notify
username shendi password 12345
codec g711ulawroouter#conf t
Enter configuration commands, one per line. End with CNTL/Z.
router(config)#voice register global
router(config-register-global)#create profile
router(config-register-global)#restartafter entering the command above appears notification : No contact info available for pool 1
why there notification?please explain to me,thanks
I set the ip on PC1 with ipv4:192.168.1.6 with subnet mask 255.255.255.0 and default-gateway 192.168.1.1
ā07-24-2015 04:39 AM
thank you for your help
ā02-15-2016 09:28 AM
Try this:
voice service voip
sip
no registrar server
no tftp-path flash
no create profile
reset
tftp-path flash:
create profile
voice service voip
sip
registrar server
reset you phone and test again
Best regards!
