No debug output on Voice Gateway, despite of term mon
CapriciousX
Hello Guys,
I have experienced a strange thing and do not know why it happens, as it has worked before. For troubleshooting purposes I have always used "debug isdqn q931", but since a few weeks I cannot see the output. As usual I have typed in "term mon", but it does not work at all on every Gateway. I got nothing on the vty line. The same for my colleauge. We use putty.
Any idea for helping me?
Thanks!
hahha ...Happens to the best of us :|
D_Lebedev
Level 3
Level 3
Have you checked same connected through cmd---telnet?
Without any third party telnet apps?
Try to connect from another station if possible.
Yes, I did, I also checked on that with a other SSH Client (SecureCrt) and even with another station  - just NOTHING. I don't get it :-( .
debug is definitely turned on
debug isdn error is             ON.
debug isdn event is             ON.
debug isdn q921 is              ON.   (filter is OFF)
debug isdn q931 is              ON.   (filter is OFF)
OK Guys I got it by myself.
I do not know why but the command "logging on" and "logging monitor debugging" weren't  typed in. Now I need to find the guy who turned it off ;-).
