01-26-2011 07:29 AM - edited 03-16-2019 03:05 AM
Hello Guys,
I have experienced a strange thing and do not know why it happens, as it has worked before. For troubleshooting purposes I have always used "debug isdqn q931", but since a few weeks I cannot see the output. As usual I have typed in "term mon", but it does not work at all on every Gateway. I got nothing on the vty line. The same for my colleauge. We use putty.
Any idea for helping me?
Thanks!
Solved! Go to Solution.
01-26-2011 10:08 AM
hahha ...Happens to the best of us :|
01-26-2011 07:39 AM
Have you checked same connected through cmd---telnet?
Without any third party telnet apps?
Try to connect from another station if possible.
01-26-2011 07:53 AM
Yes, I did, I also checked on that with a other SSH Client (SecureCrt) and even with another station - just NOTHING. I don't get it :-( .
debug is definitely turned on
debug isdn error is ON.
debug isdn event is ON.
debug isdn q921 is ON. (filter is OFF)
debug isdn q931 is ON. (filter is OFF)
01-26-2011 07:57 AM
OK Guys I got it by myself.
I do not know why but the command "logging on" and "logging monitor debugging" weren't typed in. Now I need to find the guy who turned it off ;-).
01-26-2011 10:08 AM
