55
Highlighted
Beginner
No Devpack Available - Communications Manager
I have a requirement to deploy Cisco 8811 IP Phones on our current Communications Manager 10.0.1 which it at present does not support.  According to the compatibility matrix there is "No Devpack Available" for this version.  There is a devpack available for version 10.5.1 however this system is running under HCS version 10.0.1 which prevents me from upgrading to 10.5.1.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
Does anyone know if it is possible to apply the 10.5.1 devpack to 10.0.1 Communications Manager?  If not, is there any other way to deploy an 8811 on version 10.0.1?
1 REPLY 1
Highlighted
Hall of Fame Cisco Employee
No, the DevPacks are tied to a CUCM version, you'll get an error if you try.
I don't see any device enabler, but sometimes they're not available on cisco.com, you can try opening a TAC to find out if there is, and to have them publish it for you.
java
if this helps, please rate
