ā12-18-2013 05:30 AM - edited ā03-16-2019 08:55 PM
Hi all,
I have a lot of problems with cisco 2911 with IOS: c2900-universalk9-mz.SPA.152-4.M5 in FXS port.
I don't have dial tone in FXS port, always busy.
I configured the port as stcapp, Incoming calls works ok, but there is no dial tone.
I done upgrade downgrade, port is working fine with STACPP in C-881 V (dial tone is ok) but not in cisco 2911.
Any idea?
Regards.
ā12-18-2013 05:43 AM
Hi;
Try applying:
cptone (followed by country code i.e. GB for the UK) to the analogue voice ports
ā12-18-2013 06:25 AM
In addition to above, You need to configure correct "Locale" on CUCM for that endpoint(analog port). This will configure automatically correct cptone value under that analog voice port.
Br,
Nadeem
Please rate all useful post.
ā12-18-2013 06:36 AM
Hi.
If you are in a CME setup using STCAPP, verify that you have a dialpeer using service stcapp followed by port X/X/X where FXS is located
Carlo
Please rate all helpful posts
"The more you help the more you learn"
ā02-05-2017 02:54 PM
I have VG204 (MGCP), I dont have dial tone on all 4 FXS ports. Port 0/0 is configured as POTS and port0/1 as LS. Below is the configuration I have on ports and dial peers.
dial-peer voice 200 pots
service stcapp
port 0/1
dial-peer voice 201 pots
service stcapp
port 0/1
dial-peer voice 202 pots
service stcapp
port 0/2
dial-peer voice 203 pots
service stcapp
port 0/3
dial-peer voice 9990099 pots
service mgcpapp
port 0/0
dial-peer voice 9990199 pots
service mgcpapp
port 0/1
voice-port 0/0
timeouts ringing infinity
caller-id enable
voice-port 0/1
caller-id enable
voice-port 0/2
caller-id enable
voice-port 0/3
caller-id enable
CUCM ver is 11.5, ios is 15.4.
