NO Dial tone on FXS port when Prefix DN is configured in CUCM
richard.leclerc
In CUCM 9.1, I noticed that there is no dial tone on FXS port on VG224 when prefix DN is configured in CUCM.
If we remove the prefix DN, then we can make calls. This seems to be new because this is working in CUCM 6.1 and 7.1.
Any parameter to change on VG or in CUCM?
Robert Thomas
Level 7
Level 7
I remember running into a case like this in the past. I dont remember too much right now since it was a while back, but if my memory is correct it was a change of functionality or a caveat.
I can try to pull up my notes sometime tomorrow and report back.
Would be great if you can.
I tried to find any bug or parameter but no luck
jasonmdahl
I have been having this exact same issue, when we add the prefix DN it doesn't work.
Jason
Josue Diaz
I have the same problem. Does anyone know how to solve this or what could be causing this issue?
Thanks.
