No Dialtone on FXS ports on MGCP VG202
Lucky19th
Hi All,
I have configured a VG202 gateway using MGCP on my CUCM version 8.5.I have also configured a Analog port which shows as registered on my CUCM.
However, I am getting no dialtone on the analog phone I have plugged in on the FX 0/0 port.
When I call the DN allocated to that port from a IP phone, i can the ringing tone and the light on the VG202 for that port goes on. But on the analog handset I get nothing.
See my config on the VG202 below.
Thanks for your help in advance. Let me know if any other details would help troubshooting this.
version 12.4
no service pad
hostname lonfgw01
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$n0XN$9v/ZD6rKywN1YGFxHVIFW0
no aaa new-model
ip source-route
ip cef
ip domain name fqm.internal
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.12.0.4 255.255.255.0
speed auto
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.12.0.1
no ip http server
control-plane
voice-port 0/0
voice-port 0/1
ccm-manager redundant-host 10.22.16.41
ccm-manager mgcp
ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.22.16.41
ccm-manager config
mgcp
mgcp call-agent 10.22.16.42 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 99900 pots
service mgcpapp
port 0/0
dial-peer voice 99901 pots
service mgcpapp
port 0/1
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login
end
lonfgw01#
boris.kudr
hi mate,
I know it sounds stupid, but make sure that your phone has ringer enabled and it's connected into correct VG202 port using proper cable.
What happens if you pickup the handset while light flashes on the VG202? Do you get connected?
Also please post "show ccm" output from the affected VG.
UPD: Make sure you reset gateway in CUCM after you make changes to gw configuration there.
Cheers,
Boris
Hi Boris,
Thanks for your time. I have checked the cable and handset. They are fine on a standard analog line.
I tried picking up the handset while ringing the DN ( the status light was ON on the vg202) but the handset was not responding in any fashion.
Please see the configs you mentioned below.
lonfgw01#sh mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 10.22.16.42 2427 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay for VoIP is SDP controlled
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough mode: NSE, codec: g711ulaw, redundancy: DISABLED,
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP rtp unreachable timeout 1000 action notify
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED
MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED
MGCP simple-sdp ENABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000
MGCP playout mode is adaptive 60, 40, 1000 in msec
MGCP Fax Playout Buffer is 300 in msec
MGCP media (RTP) dscp: ef, MGCP signaling dscp: af31
MGCP default package: line-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
                         hs-package rtp-package atm-package ms-package dt-package
                         mt-package sst-package fxr-package md-package
MGCP Digit Map matching order: shortest match
SGCP Digit Map matching order: always left-to-right
MGCP VoAAL2 ignore-lco-codec DISABLED
MGCP T.38 Max Fax Rate is DEFAULT
MGCP T.38 Fax is ENABLED
MGCP T.38 Fax ECM is DISABLED
MGCP T.38 Fax NSF Override is DISABLED
MGCP T.38 Fax Low Speed Redundancy: 0
MGCP T.38 Fax High Speed Redundancy: 0
MGCP Fax relay SG3-to-G3: ENABLED
MGCP Fax relay ANSam suppression: DISABLED
MGCP control bind :DISABLED
MGCP media bound to interface FastEthernet0/0
MGCP Upspeed payload type for G711ulaw: 0,  G711alaw: 8
MGCP Dynamic payload type for Cisco fax indication: 96, Cisco fax ack: 97
MGCP Static payload type for G.726-16K codec
MGCP Dynamic payload type for G.726-24K codec
MGCP Dynamic payload type for G.726-32K codec
MGCP Dynamic payload type for G.Clear codec
MGCP Dynamic payload type for NSE is 100
MGCP Dynamic payload type for NTE is 99
MGCP rsip-range is enabled for TGCP only.
MGCP Comedia role is NONE
MGCP Comedia check media source is DISABLED
MGCP Comedia SDP force is DISABLED
MGCP g729 variants use static payload type and contain annexb in SDP
MGCP Guaranteed scheduler time is DISABLED
MGCP Disconnect delay error recovery DISABLED
MGCP DNS stale threshold is 30 seconds
lonfgw01#sh ccm
lonfgw01#sh ccm-manager
MGCP Domain Name: lonfgw01.fqm.internal
Priority        Status                   Host
Primary         Registered               10.22.16.42
First Backup    Backup Ready             10.22.16.41
Second Backup   None
Current active Call Manager:    10.22.16.42
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            08:15:26 GMT Feb 24 2012 (elapsed time: 00:00:11)
Last MGCP traffic time:         08:15:26 GMT Feb 24 2012 (elapsed time: 00:00:11)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Configuration Auto-Download Information
Current version-id: 1330012374-ae66f292-afff-42ec-a079-d2a948cbe118
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
        Download Attempted             : 1
          Download Successful          : 1
          Download Failed              : 0
        Configuration Attempted        : 1
          Configuration Successful     : 1
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command: New Registration
Hey,
Did you find a resolution to this ???
any help will be appreciated.
Shabeeb
