Hello Everybody
actually i have a problem with my VG, my scenario is as below,
PSTN--> (12*FXO / 1*E1) --> CUC (Greeting Call Handler)--> CUCM
and Vocie Gateway is 29211 with 1* PVDM3-64 and 1* PVDM3-32
The Problem is, on some FXO ports (its RANDOM), after a while, when i get "show Vocie Call Status" its give me the No DSP on calls
and when this issue is happened, VG does not allow Incoming and Outgoing Calls and actually no calls
does anybody have suggestion about it????
thank you in advance
John
Hi John,
Have you configured the voice card on the router like below
voice-card 0
dspfarm
dsp services dspfarm
Also, card type
card type {t1 | e1}
Try configuring it and if it does not work, please provide show tech from the gateway.
Manish
- Do rate helpful posts -
thanks for your replay
actually i have this problem on my FXO ports
but at this time, i clear all my configuration under FXO port (such as CPtone, Supervisory , ...) and my problem was solved,
Good to know that the issue is resolved, thanks for updating the post.
Manish
Dear Manish
unfortunately the error was back today
here is the show dsp output
and show call voice summary
dsp 1:
State: UP, firmware: 37.3.10
Max signal/voice channel: 32/32
Max credits: 480, Voice credits: 480, Video credits: 0
num_of_sig_chnls_allocated: 32
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 450, reserved credits: 0
Signaling channels allocated: 32
Voice channels allocated: 2
Credits used (rounded-up): 30
Voice channels:
Ch01: voice port: 0/3/3, codec: None, credits allocated: 15
Ch02: voice port: 0/0/0:15.28, codec: g711ulaw, credits allocated: 15
Slot: 0a
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x715 1F4A 0x2315CC14 0/1/2 No DSP 2299 None 24/20
0x718 1F4A 0x23160070 0/2/0 No DSP *2299 None 20/24
and i try to do what you said on Vocie-card 0
so i will update you on it tomorrow
thank you
still have problem , and show no dsp and incomming calls are not work
Can you share the running config and debug voice ccapi inout for a failed call.
Manish
actually because i dont know when it happened its not possible to have debug output, but here is my running config
Note: 2299 is my Call Handler Number n CUC, and i reduce the output for 4 FXO because they are the same
VG-RTR-2921#sh run
Building configuration...
version 15.4
service password-encryption
hostname VG-BUT-RTR-2921
boot-start-marker
boot system flash0:/c2900-universalk9-mz.SPA.154-3.M4.bin
boot-end-marker
card type e1 0 0
no aaa new-model
network-clock-participate wic 0
no ip domain lookup
ip cef
no ipv6 cef
isdn switch-type primary-net5
trunk group Outgoing-FXO
hunt-scheme longest-idle
cts logging verbose
voice-card 0
dspfarm
voice call send-alert
voice rtp send-recv
voice service pots
fax rate disable
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback pass-through g711ulaw
no fax-relay sg3-to-g3
h323
no h225 timeout keepalive
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
codec preference 5 g722-48
codec preference 6 g722-56
codec preference 7 g722-64
voice class custom-cptone I
dualtone busy
frequency 425 425
cadence 500 500
dualtone ringback
frequency 425 425
cadence 1000 4000
dualtone disconnect
frequency 425 425
cadence 250 250
voice translation-rule 1
rule 1 /.+/ /2299/
voice translation-profile IncomingProfile_1
translate called 1
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
shutdown
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.200.20 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation ppp
isdn incoming-voice modem
isdn sending-complete
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.200.1
control-plane
voice-port 0/0/0:15
bearer-cap Speech
voice-port 0/1/0
trunk-group Outgoing-FXO
no vad
connection plar opx 2299
caller-id enable
voice-port 0/1/1
no vad
caller-id enable
voice-port 0/1/2
no vad
caller-id enable
voice-port 0/1/3
no vad
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 100 voip
description "_Outgoing to CUCM_"
destination-pattern [1-5]..
session target ipv4:192.168.200.10
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 10 pots
description Incoming-PSTN-E1 0/0/0
translation-profile incoming IncomingProfile_1
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 2299 voip
destination-pattern 2299
codec g711ulaw
no vad
dial-peer voice 20 pots
trunkgroup Outgoing-FXO
description ROutgoing__local 4 digit"
destination-pattern ....
forward-digits all
dial-peer voice 21 pots
description ROutgoing__local 5 digit"
destination-pattern .....
forward-digits all
dial-peer voice 22 pots
description ROutgoing__local 6 digit"
destination-pattern ......
forward-digits all
dial-peer voice 23 pots
description ROutgoing__local 7 digit"
destination-pattern [2-9]......
forward-digits all
dial-peer voice 24 pots
description ROutgoing__local 8 digit"
destination-pattern [2-9].......
forward-digits all
dial-peer voice 50 pots
description Incomming-PSTN
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
gatekeeper
shutdown
scheduler allocate 20000 1000
ntp server 192.168.1.9 prefer
end
Hi John,
Is the issue seen with this config as well? Are any calls being impacted?
Manish
yes, this it my final config
Hi John,
Can you share the "show voice dsp" and "debug voice ccapi inout" , "show voice port summary" output for a failed call when the issue is seen.
Manish
You have one loop back and interface. I think you may need bind h323 interfaces. Is any way to post debug voice ccapi inou.?
Like Manish said please post debugs:
is this h323 gateway ? if it is you need to bind the interface..
Hi Samuel
this is H323 Gateway
