06-05-2017 12:58 PM - edited 03-17-2019 10:30 AM
Hola a todos,
Estoy configurando un 4331 con una NIM-2MFT-T1/E1 pero no puedo configurar la señalización R2, el comando para r2-digital no se encuentra disponible en el router.
Router_Voice(config)#controller e1 0/1/0
Router_Voice(config-controller)#ds0-group 0 timeslots 1-15 type r2-digital
% Invalid input detected at '^' marker.
Router_Voice(config-controller)#ds0-group 0 timeslots 1-15 type ?
e&m-delay-dial E & M Delay Dial
e&m-immediate-start E & M Immediate Start
e&m-melcas-delay MEL CAS (CEPT) E & M Delay Start
e&m-melcas-immed MEL CAS (CEPT) E & M Immediate Start
e&m-melcas-wink MEL CAS (CEPT) E & M Wink Start
e&m-wink-start E & M Wink Start
fxo-ground-start FXO Ground Start
fxo-loop-start FXO Loop Start
fxo-melcas MEL CAS (Mercury) FXO
fxs-ground-start FXS Ground Start
fxs-loop-start FXS Loop Start
fxs-melcas MEL CAS (Mercury) FXS
Me pueden ayudar por favor?
Aqui se encuentra el show version y el show run
Router_Voice#sh ver
Cisco IOS XE Software, Version 03.13.04.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 05-Oct-15 11:24 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router_Voice uptime is 2 hours, 16 minutes
Uptime for this control processor is 2 hours, 17 minutes
System returned to ROM by reload
System image file is "bootflash:/isr4300-universalk9.03.13.04.S.154-3.S4-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appx None None None
uc uck9 Permanent uck9
security None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1687137K/6147K bytes of memory.
Processor board ID FLM2101W1BJ
3 Gigabit Ethernet interfaces
2 Channelized E1/PRI ports
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
Router_Voice#sh run
Building configuration...
Current configuration : 2489 bytes
! Last configuration change at 19:38:14 UTC Mon Jun 5 2017
version 15.4
no platform punt-keepalive disable-kernel-core
hostname Router_Voice
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
enable secret 5 $1$NJEv
aaa new-model
aaa session-id common
ip domain name Mer.com
subscriber templating
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12 advertise-only
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call start slow
sip
header-passing
registrar server expires max 3600 min 3600
voice-card 0/1
dsp services dspfarm
no watchdog
voice-card 0/4
no watchdog
license udi pid ISR4331/K9 sn FDO205124SC
username Cisco secret Cisco
redundancy
mode none
controller E1 0/1/0
framing no-crc4
controller E1 0/1/1
framing no-crc4
interface GigabitEthernet0/0/0
no ip address
speed 1000
no negotiation auto
interface GigabitEthernet0/0/0.90
encapsulation dot1Q 90
ip address 172.X.X.X 255.255.255.0
no cdp enable
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface Service-Engine0/1/0
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 172.19.90.1
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
transport input ssh
network-clock synchronization automatic
end
