03-22-2011 08:03 AM - edited 03-16-2019 04:05 AM
We have the following configuration at a remote site and have issues with incoming calls when in fallback mode, outgoing calling works fine, but incoming gives busy tone. Can someone see anything wrong with the config? Thanks.
03-22-2011 08:10 AM
Can u run the cmd:
debug isdn q931
and
debug voice ccapi inout
Make an incoming call and post the debg outputs.
03-22-2011 08:44 AM
A very similar configuration structure to how I configure SRST.
Try applying your translation profile to the voice port rather than the incoming dial-peer, as that is the only obvious difference I can see.
Cheers,
Alistair
03-22-2011 08:53 AM
Yeah your missing a translation pattern. Here's an example for what you need to do for your VGR:
* PSTN sending us the last 4 signifcant digits of our DID. And we have a phone using DN 2303
voice translation-rule 100
rule 1 /3600/ /2303/
voice translation-profile voice
translate called 100
dial-peer voice 1 pots
translation-profile incoming voice
incoming called-number .
direct-inward-dial
port 0/0/0:23
-rya
03-23-2011 12:09 AM
Thanks, I 'll try the suggested and get debugs if necessary...Will post back soon.
03-23-2011 07:43 AM
As ryabutler put in his dialpeer config you should put in the "incoming called number ." command in dial-peer voice 1 pots. I am guessing that if you run a debug you will see incoming calls matching on dial-peer 1. You could probably just shut down that dial peer then then they will match on dial peer 2 and all should work fine I would guess. But i would add the command that ryabutler told you to add then give it a try.
Here is a doc you can reference for when you are experiencing no imcoming calls when running mgcp with your srst config on isdn or pots lines.
