06-01-2011 06:03 AM - edited 03-16-2019 05:14 AM
Just moticed strange thing.
After pressing i-button on idle phone (7945G, 7965) help contents appears after some time, but navigation softkeys on a display have no name written on it - it is just rectangular areas on a display! Though they function properly - you can navigate with them. This problem appears only if I use Russian user locale - with English locale I see names on softkeys.
I use 7.1.5.30000-1 version. What can be the problem?
06-01-2011 07:24 AM
Try upgrade phone firmware, if same issue then it should be a Bug. If this happens to all that ip phone models then try to contact TAC.
06-02-2011 12:01 AM
Thanks for answering.
I already loaded latest (from 24th of May) FW.
OK then let's TAC handle this.
06-03-2011 12:43 AM
Problem resolved.
The solution - always install the latest locales! For phone only it is now 9.2.1. After installation everything is OK.
