06-28-2011 07:18 AM - edited 03-16-2019 05:40 AM
Hello all,
I've a strange problem with UCM SB 8.0.3.22900-5 installation.
Users complain that 90% of the times they put calls on hold aren't able to resume the call back since the Resume button isn't available. This isn't my first voip installation so I think that this UCM release has problems as the 8.0.2 used.
This is the scenario:
GW H323 (E1 PRI LINK) <--> UCM <--> PHONE
Do you have any suggestion? Did you ever encounter the problem?
many thanks for your attention
Lorenz
Solved! Go to Solution.
06-28-2011 10:17 AM
Have you tried checking the MTP required on the GW config?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-28-2011 10:17 AM
java
06-29-2011 01:33 AM
Yes now it works. But why?
