09-24-2014 09:44 AM - edited 03-17-2019 12:17 AM
Hi everyone recently i created a SIP-TRUNK connection to an VOIP service provider, the calls works just fine but the ring-back tone since you dial the number until someone answers were unable to hear it!!! Does any one know why???
Thanks for your comments,
Solved! Go to Solution.
09-24-2014 12:00 PM
09-24-2014 10:57 AM
is it CUCM or CME?
If it is CUCM, is it SIP trunk between to GW or H323?
can you collect "debug ccsip message" for a call and provide the calling/called numbers and also the GW configuration?
09-24-2014 11:13 AM
09-24-2014 11:24 AM
09-24-2014 11:38 AM
oh ok great so teh problem is H323, why i have it that way, i dont know i didnt configure it maybe because at first the sip trunk wanst on the plan, i really dont have a lot of knowledge in VOIP, how can i change the h323 to sip??
do you a guide or something ?
that will solve the problem??
THANKS FOR ALL YOUR HELP
09-24-2014 12:00 PM
