09-02-2013 02:11 AM - edited 03-16-2019 07:09 PM
I'm facing issue that our customers don't hear ringback tone when they are calling to queueing enabled pilot during transfer to agent.
The welcome message is played and then is silence till agent pick up call.
I have read http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_0_1/ccmfeat/CUCM_BK_CEF0C471_00_cucm-features-and-services-guide_chapter_0111.html but there is only something about h323, but I'm using SIP trunk.
Schema:
PSTN -> sip trunk -> Cisco 2801 -> dialpeer -> sip trunk -> cucm 9 -> hunt pilot with queueing enabled
Does anybody know how to fix it?
09-02-2013 02:29 AM
HI Tibor.
Do you have MRGL containing Annunciator on Sip Trunk Configuration?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-02-2013 02:32 AM
Yes of course
09-02-2013 02:42 AM
Can you post a debug ccsip messages during a call to the pilot?
Carlo
09-02-2013 03:34 AM
Our IP replaced by 9.9.9.9.
006250: Sep 2 12:29:57: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:222555120@9.9.9.9:5060 SIP/2.0
Record-Route: <195.122.201.178>
Via: SIP/2.0/UDP 195.122.201.178;branch=z9hG4bK13f3.efc535f5.0
Via: SIP/2.0/UDP 195.122.222.128:5060;branch=z9hG4bK1219ACE250C
To: <222555120>
Date: Mon, 02 Sep 2013 10:29:57 GMT
Call-ID: 72B11235-12F111E3-8C35B98C-2D8E382F@195.122.222.128
Supported: timer,replaces
Min-SE: 1800
Cisco-Guid: 1924167181-317788643-2451243022-3619253138
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 69
Remote-Party-ID: <733700128>;party=calling;screen=yes;privacy=off
Timestamp: 1378117797
Contact: <733700128>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 339733700128>733700128>222555120>733700128>195.122.201.178>
v=0
o=CiscoSystemsSIP-GW-UserAgent 7253 9283 IN IP4 195.122.222.128
s=SIP Call
c=IN IP4 195.122.222.128
t=0 0
m=audio 17834 RTP/AVP 18 3 8 0 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:3 GSM/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
006251: Sep 2 12:29:57: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 195.122.201.178;branch=z9hG4bK13f3.efc535f5.0,SIP/2.0/UDP 195.122.222.128:5060;branch=z9hG4bK1219ACE250C
To: <222555120>
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0222555120>733700128>
006252: Sep 2 12:29:57: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:222555120@192.168.100.12:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.2:5060;branch=z9hG4bK19081E2D
Remote-Party-ID: <0733700128>;party=calling;screen=yes;privacy=off
To: <222555120>
Call-ID: 72B877BF-12F111E3-B8FB8147-7C16CA@192.168.100.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Contact: <0733700128>
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 2500733700128>222555120>0733700128>0733700128>
v=0
o=CiscoSystemsSIP-GW-UserAgent 8150 1870 IN IP4 192.168.100.2
s=SIP Call
c=IN IP4 192.168.100.2
t=0 0
m=audio 17056 RTP/AVP 8 101
a=fmtp:101 0-16
a=ptime:20
006253: Sep 2 12:29:57: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <222555120>
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0222555120>0733700128>
006254: Sep 2 12:29:57: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <222555120>;tag=20654~8b8bab4f-5d6f-4c12-a38d-a436a7092159-20399875
CSeq: 101 INVITE
Require: 100rel
RSeq: 2044079417
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Remote-Party-ID: "Helpdesk" <2120>;party=called;screen=yes;privacy=off
Contact: <222555120>
Content-Length: 251222555120>2120>222555120>0733700128>
v=0
o=CiscoSystemsCCM-SIP 20654 1 IN IP4 192.168.100.12
s=SIP Call
c=IN IP4 192.168.100.12
b=TIAS:64000
b=AS:64
t=0 0
m=audio 4000 RTP/AVP 8 101
a=ptime:20
a=sendonly
a=fmtp:101 0-15
006255: Sep 2 12:29:57: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:222555120@192.168.100.12:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.2:5060;branch=z9hG4bK1909131E
CSeq: 102 PRACK
RAck: 2044079417 101 INVITE
Max-Forwards: 70
006256: Sep 2 12:29:57: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <222555120>;tag=A503BF50-2366
CSeq: 101 INVITE
Contact: <9.9.9.9:5060>
Supported: sdp-anat
Content-Length: 259195.122.201.178>9.9.9.9:5060>2120>222555120>733700128>
v=0
o=CiscoSystemsSIP-GW-UserAgent 1228 7893 IN IP4 9.9.9.9
s=SIP Call
c=IN IP4 9.9.9.9
t=0 0
m=audio 17484 RTP/AVP 8 101
c=IN IP4 9.9.9.9
a=sendonly
a=fmtp:101 0-16
a=ptime:20
006257: Sep 2 12:29:57: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
006258: Sep 2 12:29:59: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 2044079418
Content-Length: 0222555120>2120>222555120>0733700128>
006259: Sep 2 12:29:59: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.100.2:5060;branch=z9hG4bK190A17C8
CSeq: 103 PRACK
RAck: 2044079418 101 INVITE
Max-Forwards: 70
006260: Sep 2 12:29:59: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0195.122.201.178>222555120>2120>222555120>733700128>
006261: Sep 2 12:29:59: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Mon, 02 Sep 2013 10:29:59 GMT
CSeq: 103 PRACK
006262: Sep 2 12:30:05: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:222555120@9.9.9.9:5060 SIP/2.0
To: <222555120>
CSeq: 101 CANCEL
Max-Forwards: 70
User-Agent:SIP_PROXY_VOLNY_a.s.
006263: Sep 2 12:30:05: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <222555120>
Date: Mon, 02 Sep 2013 10:30:05 GMT
CSeq: 101 CANCEL
006264: Sep 2 12:30:05: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:222555120@192.168.100.12:5060 SIP/2.0
To: <222555120>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1378117805
Reason: Q.850;cause=16
006265: Sep 2 12:30:05: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
006266: Sep 2 12:30:05: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:222555120@9.9.9.9:5060 SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
006267: Sep 2 12:30:05: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <222555120>
CSeq: 101 CANCEL
006268: Sep 2 12:30:05: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
006269: Sep 2 12:30:05: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
09-02-2013 03:46 AM
apply this command in voice gateway and try:
voice service voip
supplementary-service sip moved-temporarily
or
voice call send-alert (global configuration command)
Selvarathnam
09-02-2013 03:51 AM
didn't help. I tried first, second first+second
09-02-2013 05:23 AM
Update: when I turned off "MTP required" on SIP trunk, ring back is working. But it would be better to have it enabled for us.
09-02-2013 05:32 AM
Hi Tibor.
Try to disable relxx on both CUBE and CUCM and see if it maskes difference.
Which IOS are you running?
Carlo
