08-07-2016 09:38 PM - edited 03-17-2019 07:45 AM
Peeps, I am having the following issue, where outbound calls do not establish outbound audio (so the called party cannot hear me). The diagram below shows the SIP messages, when making an outbound call through a CUBE. 10.61.2.82 is my cucm, 10.61.64.254 is my CUBE. Our SIP provider has come back to me and informed me the issue is on our CUBE, because there is no ACK sent to them, as part of the initial 101 INVITE (and I concurr, see below). The problem that I am having, is that I have no idea what to trouble shoot or play with, to understand why that ACK is not send from our CUBE to the provider.
I obviously already ran debug ccsip message on my CUBE, but there is no apparent clue in that.
Below are the SIP ladders for a failing call and for an successful call, interestingly the successful cal sends a 183 session progress sip update coming from the provider, the failing call hasnt got that.
any one any suggestions?
FAILING CALL:
SUCCESSFUL CALL:
08-07-2016 11:06 PM
Your CUBE is using EO while your CUCM uses DO. Change your CUCM to use EO as well and check.
Also, please share the debugs of the failed call, I think the Re-INVITE isn't going to the right destination IP based on your ladder.
08-08-2016 04:02 PM
Thanks Mo, agreed that one leg is DO and the CUBE outbound leg is EO, I will play with these settings. But remember that we do have successful calls even though there is a mix of DO and EO.
08-08-2016 11:33 PM
Agreed. EO-DO combi should work. I just want to see if it makes difference. Also, I would like to see the debugs for failed call if possible.
