no valid upgrade options were found
Yazen Alaa
Dear
I have CCM 7.1.5 and i am tring to upgrade 7921G device pack but it is giving me " no valid upgrade options were found " and i am using FreeSFTP
do you what is the problem that i faced and how to solve it ????
Note : please see the attached file to see the error
thanks and regards
15 Replies 15
No, that's completely wrong, if this is related to using FreeFTPd as the backup client, see my old reply.
In any case, CUCM DOES NOT create any folders for this, CUCM only READS
java
if this helps, please rate
