hello Folks , i m setting my voice lab , i have cucm and cisoco router 3845 , i have configured mgcp gateway and did the pri config from cucm , i using qsig and two port of router 0/0/0 and 0/0/1 ,now layer 1 and layer 3 is active but layer 2 is not showing multi frame establihed . pls help , thanks in advance
rgds
KS
L3 can't be active if L2 is down. Share your MGCP IOS Config and debug mgcp packets
Hello Mohammed et all
Please have a look at traces below:
KS
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.06.05 19:31:04 =~=~=~=~=~=~=~=~=~=~=~=
*Jun 5 13:54:02.575: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
MGC1#sh logg
*Jun 5 13:54:11.991: mgcpapp_stw_call_back timer type 0
*Jun 5 13:54:11.991: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:54:11.991: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:54:11.991: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6B0F0,trans_id:529089074,*msgp:0xC0EEC2A4,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:7
*Jun 5 13:54:11.991: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DA10,firstsent_ts:60912,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:54:11.991: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:54:11.991: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:54:11.991: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:54:11.991: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
MGC1#sh logg
*Jun 5 13:54:11.991: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:54:11.991: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:54:11.991: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:54:12.991: mgcpapp_stw_call_back timer type 0
*Jun 5 13:54:12.991: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:54:12.991: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:54:12.991: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0xC0D6AE60,trans_id:529089075,*msgp:0x6663D6F4,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:7
*Jun 5 13:54:12.991: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A1B0,firstsent_ts:61144,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:54:12.991: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:54:12.991: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:54:12.991: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:54:12.991: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:54:12.991: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:54:12.991: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:54:12.991: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
MGC1#sh logg
*Jun 5 13:54:22.575: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
MGC1#sh logg term mon conf t debug mgcp all isdn q931 conf t end no ip look-up domain en no ip look-up domain end conf t debug isdn q931 mgcp all conf t
*Jun 5 13:54:42.575: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
MGC1#conf t term mon term mon conf t debug mgcp all isdn q931 sh
MGC1#show lo
MGC1#show logg
MGC1#show logging
Syslog logging: enabled (12 messages dropped, 77 messages rate-limited,
31 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: level debugging, 4248 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 58 messages logged, xml disabled,
filtering disabled
Logging to: vty450(58)
Buffer logging: disabled, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
No active filter modules.
Trap logging: level informational, 874 message lines logged
MGC1#
*Jun 5 13:55:02.575: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
MGC1#
*Jun 5 13:55:09.963: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
MGC1#conf sh run
Building configuration...
Current configuration : 2994 bytes
version 12.4
service config
hostname MGC1
boot-start-marker
boot-end-marker
card type e1 0 0
card type e1 0 1
card type e1 1 0
card type e1 1 1
card type e1 3 0
card type e1 3 1
card type e1 4 0
card type e1 4 1
--More--
*Jun 5 13:55:22.575: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
--More-- no aaa new-model
--More-- no network-clock-participate slot 1
--More-- no network-clock-participate slot 3
--More-- no network-clock-participate slot 4
--More-- network-clock-participate wic 0
--More-- network-clock-participate wic 1
--More-- ip cef
--More-- !
--More-- !
--More-- !
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice-card 3
no dspfarm
voice-card 4
no dspfarm
--More-- !
username cisco password 0 cisco
controller E1 0/0/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
framing NO-CRC4
controller E1 0/1/0
--More--
MGC1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
MGC1(config)#
*Jun 5 13:55:42.575: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
MGC1(config)#logg
MGC1(config)#logging bugg
*Jun 5 13:55:50.963: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
MGC1(config)#logging bugg ff
MGC1(config)#logging buffered ?
<0-7> Logging severity level
<4096-2147483647> Logging buffer size
alerts Immediate action needed (severity=1)
critical Critical conditions (severity=2)
debugging Debugging messages (severity=7)
emergencies System is unusable (severity=0)
errors Error conditions (severity=3)
filtered Enable filtered logging
informational Informational messages (severity=6)
notifications Normal but significant conditions (severity=5)
warnings Warning conditions (severity=4)
xml Enable logging in XML to XML logging buffer
MGC1(config)#logging buffered 100000
MGC1(config)#
*Jun 5 13:56:02.575: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
MGC1(config)#^Z
MGC1#
*Jun 5 13:56:05.523: %SYS-5-CONFIG_I: Configured from console by cisco on vty0 (172.18.150.151)
MGC1#sh logg
MGC1#sh logging
Console logging: level debugging, 4255 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 65 messages logged, xml disabled,
filtering disabled
Logging to: vty450(65)
Buffer logging: level debugging, 2 messages logged, xml disabled,
filtering disabled
Trap logging: level informational, 881 message lines logged
--More--
Log Buffer (100000 bytes):
MGC1#
MGC1#
MGC1#
MGC1#
MGC1#
MGC1#
MGC1#
*Jun 5 13:56:22.575: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
MGC1#
MGC1#
MGC1#
MGC1#
*Jun 5 13:56:31.971: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/mgc1-confg) failed
MGC1#
MGC1#
MGC1#
MGC1#
*Jun 5 13:56:34.043: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected)
*Jun 5 13:56:34.043: mgcp_app_info_about_port_update: vdbptr = C0A99C30
*Jun 5 13:56:34.043: mgcp_app_info_about_port_update: vdbptr C0A99C30, slot 0, ctrl no 0, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:56:34.043: MGCP sys msg: (6)
*Jun 5 13:56:34.043: xlate sys msg: (6, C0873A04)
*Jun 5 13:56:34.043: sys msg values: (INVALID MGCP EVENT, 0, , 1648912992, CALL_IDLE)
*Jun 5 13:56:34.043: mgcp_interface_rem_ds0_grp: slot 0, ctrl no=0, timeslots=4294901758, vdb=C0A99C30
*Jun 5 13:56:34.043: xgcp_endpt_get_by_ifn
*Jun 5 13:56:34.043: xgcp_endpt_get_dsx_by_ifn
*Jun 5 13:56:34.043: xgcp_endpt_get_tree_link_by_ifn
*Jun 5 13:56:34.043: xgcp_endpt_compute_key- type 0 slot 0000 subunit 0000
*Jun 5 13:56:34.043: xgcp_endpt_get_tree_link_by_ifn : computed key 0x00000000
*Jun 5 13:56:34.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/*
*Jun 5 13:56:34.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/*
*Jun 5 13:56:34.043: S0/SU0/DS1-0/* mgcpapp_rsip_ds0_grp_down vdbptr = C0A99C30
*Jun 5 13:56:34.043: xgcp_endpt_get_ds0_group_from_ds1 endpt S0/SU0/DS1-0/*
*Jun 5 13:56:34.043: S0/SU0/DS1-0/* mgcp_default_gw_dlcx:
*Jun 5 13:56:34.043: xgcp_endpt_get_first
*Jun 5 13:56:34.043: xgcp_endpt_get_first_child endpt S0/SU0/DS1-0/*
*Jun 5 13:56:34.043: xgcp_endpt_ds1_get_first_child endpt S0/SU0/DS1-0/*
*Jun 5 13:56:34.043: S0/SU0/DS1-0/1 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: mgcp_delete_req_digit_filter_q
*Jun 5 13:56:34.043: mgcp_delete_qb_evt_q:cleanup QB evt q
*Jun 5 13:56:34.043: xgcp_endpt_get_next
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/1
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/1
*Jun 5 13:56:34.043: S0/SU0/DS1-0/2 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/2
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/2
*Jun 5 13:56:34.043: S0/SU0/DS1-0/3 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/3
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/3
*Jun 5 13:56:34.043: S0/SU0/DS1-0/4 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/4
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/4
*Jun 5 13:56:34.043: S0/SU0/DS1-0/5 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/5
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/5
*Jun 5 13:56:34.043: S0/SU0/DS1-0/6 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/6
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/6
*Jun 5 13:56:34.043: S0/SU0/DS1-0/7 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/7
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/7
*Jun 5 13:56:34.043: S0/SU0/DS1-0/8 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/8
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/8
*Jun 5 13:56:34.043: S0/SU0/DS1-0/9 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/9
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/9
*Jun 5 13:56:34.043: S0/SU0/DS1-0/10 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/10
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/10
*Jun 5 13:56:34.043: S0/SU0/DS1-0/11 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/11
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/11
*Jun 5 13:56:34.043: S0/SU0/DS1-0/12 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/12
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/12
*Jun 5 13:56:34.043: S0/SU0/DS1-0/13 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/13
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/13
*Jun 5 13:56:34.043: S0/SU0/DS1-0/14 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/14
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/14
*Jun 5 13:56:34.043: S0/SU0/DS1-0/15 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/15
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/15
*Jun 5 13:56:34.043: S0/SU0/DS1-0/17 mgcp_fs_gw_dlcx
*Jun 5 13:56:34
MGC1#.043: S0/SU0/DS1-0/17
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/17
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/17
*Jun 5 13:56:34.043: S0/SU0/DS1-0/18 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/18
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/18
*Jun 5 13:56:34.043: S0/SU0/DS1-0/19 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/19
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/19
*Jun 5 13:56:34.043: S0/SU0/DS1-0/20 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/20
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/20
*Jun 5 13:56:34.043: S0/SU0/DS1-0/21 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/21
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/21
*Jun 5 13:56:34.043: S0/SU0/DS1-0/22 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/22
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/22
*Jun 5 13:56:34.043: S0/SU0/DS1-0/23 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/23
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/23
*Jun 5 13:56:34.043: S0/SU0/DS1-0/24 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/24
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/24
*Jun 5 13:56:34.043: S0/SU0/DS1-0/25 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.043: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/25
*Jun 5 13:56:34.043: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/25
*Jun 5 13:56:34.043: S0/SU0/DS1-0/26 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.047: S0/SU0/DS1-0/26
*Jun 5 13:56:34.047: mgcp_delete_req_digit_filter_q
*Jun 5 13:56:34.047: mgcp_delete_qb_evt_q:cleanup QB evt q
*Jun 5 13:56:34.047: xgcp_endpt_get_next
*Jun 5 13:56:34.047: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/26
*Jun 5 13:56:34.047: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/26
*Jun 5 13:56:34.047: S0/SU0/DS1-0/27 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.047: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/27
*Jun 5 13:56:34.047: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/27
*Jun 5 13:56:34.047: S0/SU0/DS1-0/28 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.047: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/28
*Jun 5 13:56:34.047: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/28
*Jun 5 13:56:34.047: S0/SU0/DS1-0/29 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.047: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/29
*Jun 5 13:56:34.047: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/29
*Jun 5 13:56:34.047: S0/SU0/DS1-0/30 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.047: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/30
*Jun 5 13:56:34.047: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/30
*Jun 5 13:56:34.047: S0/SU0/DS1-0/31 mgcp_fs_gw_dlcx
*Jun 5 13:56:34.047: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/31
*Jun 5 13:56:34.047: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/31
*Jun 5 13:56:34.047: mgcp_ds0_group_state_change: state=1
*Jun 5 13:56:34.047: mgcp_ds0_group_set_ds0_states
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/15
MGC1#ndpt_default_set_state endpt S0/SU0/DS1-0/15
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/18
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/18
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/26
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/26
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/27
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/27
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/28
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/28
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/29
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/29
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/30
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/30
*Jun 5 13:56:34.047: xgcp_endpt_set_state endpt S0/SU0/DS1-0/31
*Jun 5 13:56:34.047: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/31
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_ds0_group_rsip:
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_ds1_max_timeslots: max_ts_bitmap FFFEFFFE ts_bitmap FFFEFFFE
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_individual_rsips_required:
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_endpt_rsip_required: restart_method=1, state=1
*Jun 5 13:56:34.047: mgcp_reconcile_rsip_method_and_state restart_method=1, state=1
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_send_rsip_to_mgc: restart_method=1, rsip_shutdown=0
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:34.047: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* Sending RSIP to (172.18.150.80) Notify entity (172.18.150.80)
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_send_rsip_msg:
*Jun 5 13:56:34.047: -- mgcp_build_packet()-
*Jun 5 13:56:34.047: - mgcp_estimate_msg_buf_length() - 328 bytes needed for header
- mgcp_estimate_msg_buf_length() - 360 bytes needed after checking parameter lines
- mgcp_estimate_msg_buf_length() - 360 bytes needed after cheking SDP lines
*Jun 5 13:56:34.047: --- mgcp_build_parameter_lines() ---
- mgcp_val_mandatory_parms()
- mgcp_build_restart_method() is called
- SUCCESS: Building Restart Method (RM:) OK
- mgcp_build_restart_delay() is called
- SUCCESS: Building MGCP Parameter lines is OK
*Jun 5 13:56:34.047: - SUCCESS: MGCP message building OK
*Jun 5 13:56:34.047: - SUCCESS: END of building
*Jun 5 13:56:34.047: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089078 S0/SU0/DS1-0/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_endpt_record_rsip:
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_send_rsip_msg: Manually recroding RSIP method
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_enq_retx_rsip_msg
*Jun 5 13:56:34.047: mgcp_add_trans_id_rec: Add trans id (529089078, C0D6AE60) record
*Jun 5 13:56:34.047: mgcp_stw_timer_start timer type 0, duration 500
*Jun 5 13:56:34.047: S0/SU0/DS1-0/* mgcp_ds0_group_reset_voice_caps
*Jun 5 13:56:34.047: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:56:34.047: %ISDN-4-ISDN_UNEXPECTED_EVENT: Se0/0/0:15: Occurred at ../isdn/isdnif_proc.c:1394
*Jun 5 13:56:34.047: ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Jun 5 13:56:34.047: ISDN Se0/0/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
*Jun 5 13:56:34.551: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:34.551: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089078,*msgp:0xC0C325C8,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:0
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6AE80,firstsent_ts:504,first_retx:1,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:34.551: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:34.551: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* retx msg again, retx_cnt=1
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* new timeout is 1000
*Jun 5 13:56:34.551: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:34.551: mgcp_stw_timer_start timer type 0, duration 1000
*Jun 5 13:56:35.043: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
*Jun 5 13:56:35.043: mgcp_app_info_about_port_update: vdbptr = C0A99C30
*Jun 5 13:56:35.043: mgcp_app_info_about_port_update: vdbptr C0A99C30, slot 0, ctrl no 0, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:56:35.043: MGCP sys msg: (5)
*Jun 5 13:56:35.043: xlate sys msg: (5, C0873A18)
*Jun 5 13:56:35.043: sys msg values: (INVALID MGCP EVENT, 0, , 1648912992, CALL_IDLE)
*Jun 5 13:56:35.043: mgcp_interface_new_ds0_grp: vdbptr C0A99C30, slot 0, ctrl no 0, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE
*Jun 5 13:56:35.043: xgcp_endpt_create_dsx ts_bitmap: FFFEFFFE
*Jun 5 13:56:35.043: xgcp_endpt_create_dsx ds1_state: 2
*Jun 5 13:56:35.043: xgcp_endpt_get_by_ifn
*Jun 5 13:56:35.043: xgcp_endpt_get_dsx_by_ifn
*Jun 5 13:56:35.043: xgcp_endpt_get_tree_link_by_ifn
*Jun 5 13:56:35.043: xgcp_endpt_compute_key- type 0 slot 0000 subunit 0000
*Jun 5 13:56:35.043: xgcp_endpt_get_tree_link_by_ifn : computed key 0x00000000
*Jun 5 13:56:35.043: xgcp_endpt_get_ds0_group_from_ds1 endpt S0/SU0/DS1-0/*
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcpapp_rsip_ds0_grp_up:vdbptr = C0A99C30
*Jun 5 13:56:35.043: xgcp_endpt_get_state endpt S0/SU0/DS1-0/*
*Jun 5 13:56:35.043: xgcp_endpt_default_get_state endpt S0/SU0/DS1-0/*
*Jun 5 13:56:35.043: mgcp_ds0_group_state_change: state=2
*Jun 5 13:56:35.043: mgcp_ds0_group_set_ds0_states
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/15
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/15
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/18
MGC1#ult_set_state endpt S0/SU0/DS1-0/18
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/26
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/26
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/27
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/27
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/28
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/28
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/29
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/29
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/30
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/30
*Jun 5 13:56:35.043: xgcp_endpt_set_state endpt S0/SU0/DS1-0/31
*Jun 5 13:56:35.043: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/31
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_ds0_group_rsip:
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_ds1_max_timeslots: max_ts_bitmap FFFEFFFE ts_bitmap FFFEFFFE
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_individual_rsips_required:
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_endpt_rsip_required: restart_method=3, state=2
*Jun 5 13:56:35.043: mgcp_reconcile_rsip_method_and_state restart_method=3, state=2
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_send_rsip_to_mgc: restart_method=3, rsip_shutdown=0
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:35.043: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* Sending RSIP to (172.18.150.80) Notify entity (172.18.150.80)
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_send_rsip_msg:
*Jun 5 13:56:35.043: -- mgcp_build_packet()-
*Jun 5 13:56:35.043: - mgcp_estimate_msg_buf_length() - 328 bytes needed for header
- mgcp_estimate_msg_buf_length() - 344 bytes needed after checking parameter lines
- mgcp_estimate_msg_buf_length() - 344 bytes needed after cheking SDP lines
*Jun 5 13:56:35.043: --- mgcp_build_parameter_lines() ---
*Jun 5 13:56:35.043: - SUCCESS: MGCP message building OK
*Jun 5 13:56:35.043: - SUCCESS: END of building
*Jun 5 13:56:35.043: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089079 S0/SU0/DS1-0/*@MGC1 MGCP 0.1
RM: restart
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_endpt_record_rsip:
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_send_rsip_msg: Manually recroding RSIP method
*Jun 5 13:56:35.043: S0/SU0/DS1-0/* mgcp_enq_retx_rsip_msg
*Jun 5 13:56:35.043: mgcp_add_trans_id_rec: Add trans id (529089079, C0D6A190) record
*Jun 5 13:56:35.043: mgcp_stw_timer_start timer type 0, duration 500
*Jun 5 13:56:35.043: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:56:35.043: ISDN Se0/0/0:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:56:35.551: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:35.551: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089079,*msgp:0x6663D980,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:0
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A1B0,firstsent_ts:508,first_retx:1,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:35.551: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:35.551: MGCP Packet sent to 172.18.150.80:2427--->
RM: restart
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* retx msg again, retx_cnt=1
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* new timeout is 1000
*Jun 5 13:56:35.551: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:35.551: mgcp_stw_timer_start timer type 0, duration 1000
*Jun 5 13:56:35.651: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:35.651: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6A190,trans_id:529089078,*msgp:0xC0C325C8,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:1
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6AE80,firstsent_ts:1604,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:35.651: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:35.651: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* retx msg again, retx_cnt=2
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* new timeout is 2000
*Jun 5 13:56:35.651: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:35.651: mgcp_stw_timer_start timer type 0, duration 2000
*Jun 5 13:56:36.763: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:56:36.763: ISDN Se0/0/0:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:56:36.811: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:36.811: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089079,*msgp:0x6663D980,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:1
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A1B0,firstsent_ts:1768,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:36.811: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:36.811: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089079 S0/S
MGC1#U0/DS1-0/*@MGC1 MGCP 0.1
RM: restart
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* retx msg again, retx_cnt=2
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* new timeout is 2000
*Jun 5 13:56:36.811: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:36.811: mgcp_stw_timer_start timer type 0, duration 2000
*Jun 5 13:56:37.687: mgcp_check_bind_state, bind type NONE
*Jun 5 13:56:37.687: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:37.687: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6A190,trans_id:529089078,*msgp:0xC0C325C8,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:2
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6AE80,firstsent_ts:3640,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:37.687: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:37.687: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* retx msg again, retx_cnt=3
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:37.687: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:37.687: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:56:38.407: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:56:38.407: ISDN Se0/0/0:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:56:38.407: mgcp_check_bind_state, bind type NONE
*Jun 5 13:56:38.591: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:38.591: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089079,*msgp:0x6663D980,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:2
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A1B0,firstsent_ts:3548,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:38.591: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:38.591: MGCP Packet sent to 172.18.150.80:2427--->
MGC1#RSIP 529089079 S0/SU0/DS1-0/*@MGC1 MGCP 0.1
RM: restart
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* retx msg again, retx_cnt=3
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:38.591: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:38.591: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:56:39.731: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:56:39.731: ISDN Se0/0/0:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
MGC1#
*Jun 5 13:56:40.731: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:56:40.731: ISDN Se0/0/0:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:56:41.611: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:41.611: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6A190,trans_id:529089078,*msgp:0xC0C325C8,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:3
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6AE80,firstsent_ts:7564,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:41.611: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:41.611: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* retx msg again, retx_cnt=4
MGC1#
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:41.611: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:41.611: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:56:42.611: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:42.611: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089079,*msgp:0x6663D980,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:3
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A1B0,firstsent_ts:7568,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:42.611: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:42.611: MGCP Packet sent to 172.18.150.80:2427--->
RM: restart
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* retx msg again, retx_cnt=4
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:42.611: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:42.611: mgcp_stw_timer_start timer type 0, duration 4000
MGC1#
*Jun 5 13:56:42.923: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
MGC1#
*Jun 5 13:56:45.631: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:45.631: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6A190,trans_id:529089078,*msgp:0xC0C325C8,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:4
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6AE80,firstsent_ts:11584,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:45.631: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:45.631: MGCP Packet sent to 172.18.150.80:2427--->
MGC1#RSIP 529089078 S0/SU0/DS1-0/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* retx msg again, retx_cnt=5
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:45.631: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:45.631: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:56:46.631: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:46.631: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089079,*msgp:0x6663D980,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:4
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A1B0,firstsent_ts:11588,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:46.631: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:46.631: MGCP Packet sent to 172.18.150.80:2427--->
RM: restart
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* retx msg again, retx_cnt=5
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:46.631: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:46.631: mgcp_stw_timer_start timer type 0, duration 4000
MGC1#
*Jun 5 13:56:49.235: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected)
*Jun 5 13:56:49.235: mgcp_app_info_about_port_update: vdbptr = C0A99C30
*Jun 5 13:56:49.235: mgcp_app_info_about_port_update: vdbptr C0A99C30, slot 0, ctrl no 0, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:56:49.235: MGCP sys msg: (6)
*Jun 5 13:56:49.235: xlate sys msg: (6, C0873A2C)
*Jun 5 13:56:49.235: sys msg values: (INVALID MGCP EVENT, 0, , 1648912992, CALL_IDLE)
*Jun 5 13:56:49.235: mgcp_interface_rem_ds0_grp: slot 0, ctrl no=0, timeslots=4294901758, vdb=C0A99C30
*Jun 5 13:56:49.235: xgcp_endpt_get_by_ifn
*Jun 5 13:56:49.235: xgcp_endpt_get_dsx_by_ifn
*Jun 5 13:56:49.235: xgcp_endpt_get_tree_link_by_ifn
*Jun 5 13:56:49.235: xgcp_endpt_compute_key- type 0 slot 0000 subunit 0000
*Jun 5 13:56:49.235: xgcp_endpt_get_tree_link_by_ifn : computed key 0x00000000
*Jun 5 13:56:49.235: xgcp_endpt_set_state endpt S0/SU0/DS1-0/*
*Jun 5 13:56:49.235: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/*
*Jun 5 13:56:49.235: S0/SU0/DS1-0/* mgcpapp_rsip_ds0_grp_down vdbptr = C0A99C30
*Jun 5 13:56:49.235: xgcp_endpt_get_ds0_group_from_ds1 endpt S0/SU0/DS1-0/*
*Jun 5 13:56:49.235: S0/SU0/DS1-0/* mgcp_default_gw_dlcx:
*Jun 5 13:56:49.235: xgcp_endpt_get_first
*Jun 5 13:56:49.235: xgcp_endpt_get_first_child endpt S0/SU0/DS1-0/*
*Jun 5 13:56:49.235: xgcp_endpt_ds1_get_first_child endpt S0/SU0/DS1-0/*
*Jun 5 13:56:49.235: S0/SU0/DS1-0/1 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: mgcp_delete_req_digit_filter_q
*Jun 5 13:56:49.235: mgcp_delete_qb_evt_q:cleanup QB evt q
*Jun 5 13:56:49.235: xgcp_endpt_get_next
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/1
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/1
*Jun 5 13:56:49.235: S0/SU0/DS1-0/2 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/2
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/2
*Jun 5 13:56:49.235: S0/SU0/DS1-0/3 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/3
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/3
*Jun 5 13:56:49.235: S0/SU0/DS1-0/4 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/4
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/4
*Jun 5 13:56:49.235: S0/SU0/DS1-0/5 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/5
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/5
*Jun 5 13:56:49.235: S0/SU0/DS1-0/6 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/6
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/6
*Jun 5 13:56:49.235: S0/SU0/DS1-0/7 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/7
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/7
*Jun 5 13:56:49.235: S0/SU0/DS1-0/8 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/8
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/8
*Jun 5 13:56:49.235: S0/SU0/DS1-0/9 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/9
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/9
*Jun 5 13:56:49.235: S0/SU0/DS1-0/10 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/10
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/10
*Jun 5 13:56:49.235: S0/SU0/DS1-0/11 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/11
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/11
*Jun 5 13:56:49.235: S0/SU0/DS1-0/12 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/12
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/12
*Jun 5 13:56:49.235: S0/SU0/DS1-0/13 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/13
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/13
*Jun 5 13:56:49.235: S0/SU0/DS1-0/14 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/14
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/14
*Jun 5 13:56:49.235: S0/SU0/DS1-0/15 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/15
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/15
*Jun 5 13:56:49.235: S0/SU0/DS1-0/17 mgcp_fs_gw_dlcx
*Jun 5 13:56:49
MGC1#.235: S0/SU0/DS1-0/17
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/17
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/17
*Jun 5 13:56:49.235: S0/SU0/DS1-0/18 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/18
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/18
*Jun 5 13:56:49.235: S0/SU0/DS1-0/19 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/19
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/19
*Jun 5 13:56:49.235: S0/SU0/DS1-0/20 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/20
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/20
*Jun 5 13:56:49.235: S0/SU0/DS1-0/21 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/21
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/21
*Jun 5 13:56:49.235: S0/SU0/DS1-0/22 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/22
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/22
*Jun 5 13:56:49.235: S0/SU0/DS1-0/23 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/23
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/23
*Jun 5 13:56:49.235: S0/SU0/DS1-0/24 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.235: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/24
*Jun 5 13:56:49.235: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/24
*Jun 5 13:56:49.235: S0/SU0/DS1-0/25 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.239: mgcp_delete_req_digit_filter_q
*Jun 5 13:56:49.239: mgcp_delete_qb_evt_q:cleanup QB evt q
*Jun 5 13:56:49.239: S0/SU0/DS1-0/25
*Jun 5 13:56:49.239: xgcp_endpt_get_next
*Jun 5 13:56:49.239: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/25
*Jun 5 13:56:49.239: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/25
*Jun 5 13:56:49.239: S0/SU0/DS1-0/26 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.239: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/26
*Jun 5 13:56:49.239: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/26
*Jun 5 13:56:49.239: S0/SU0/DS1-0/27 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.239: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/27
*Jun 5 13:56:49.239: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/27
*Jun 5 13:56:49.239: S0/SU0/DS1-0/28 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.239: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/28
*Jun 5 13:56:49.239: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/28
*Jun 5 13:56:49.239: S0/SU0/DS1-0/29 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.239: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/29
*Jun 5 13:56:49.239: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/29
*Jun 5 13:56:49.239: S0/SU0/DS1-0/30 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.239: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/30
*Jun 5 13:56:49.239: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/30
*Jun 5 13:56:49.239: S0/SU0/DS1-0/31 mgcp_fs_gw_dlcx
*Jun 5 13:56:49.239: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/31
*Jun 5 13:56:49.239: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/31
*Jun 5 13:56:49.239: mgcp_ds0_group_state_change: state=1
*Jun 5 13:56:49.239: mgcp_ds0_group_set_ds0_states
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/15
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/18
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/18
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/26
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/26
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/27
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/27
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/28
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/28
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/29
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/29
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/30
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/30
*Jun 5 13:56:49.239: xgcp_endpt_set_state endpt S0/SU0/DS1-0/31
*Jun 5 13:56:49.239: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/31
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_ds0_group_rsip:
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_ds1_max_timeslots: max_ts_bitmap FFFEFFFE ts_bitmap FFFEFFFE
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_individual_rsips_required:
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_endpt_rsip_required: restart_method=1, state=1
*Jun 5 13:56:49.239: mgcp_reconcile_rsip_method_and_state restart_method=1, state=1
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_send_rsip_to_mgc: restart_method=1, rsip_shutdown=0
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:49.239: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* Sending RSIP to (172.18.150.80) Notify entity (172.18.150.80)
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_send_rsip_msg:
*Jun 5 13:56:49.239: -- mgcp_build_packet()-
*Jun 5 13:56:49.239: - mgcp_estimate_msg_buf_length() - 328 bytes needed for header
*Jun 5 13:56:49.239: --- mgcp_build_parameter_lines() ---
*Jun 5 13:56:49.239: - SUCCESS: MGCP message building OK
*Jun 5 13:56:49.239: - SUCCESS: END of building
*Jun 5 13:56:49.239: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089080 S0/SU0/DS1-0/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_endpt_record_rsip:
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_send_rsip_msg: Manually recroding RSIP method
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_enq_retx_rsip_msg
*Jun 5 13:56:49.239: mgcp_add_trans_id_rec: Add trans id (529089080, C0D6B0F0) record
*Jun 5 13:56:49.239: mgcp_stw_timer_start timer type 0, duration 500
*Jun 5 13:56:49.239: S0/SU0/DS1-0/* mgcp_ds0_group_reset_voice_caps
*Jun 5 13:56:49.239: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:56:49.239: %ISDN-4-ISDN_UNEXPECTED_EVENT: Se0/0/0:15: Occurred at ../isdn/isdnif_proc.c:1394
*Jun 5 13:56:49.239: ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Jun 5 13:56:49.239: ISDN Se0/0/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
*Jun 5 13:56:49.851: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:49.855: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6A190,trans_id:529089078,*msgp:0xC0C325C8,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:5
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6AE80,firstsent_ts:15808,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:49.855: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:49.855: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* retx msg again, retx_cnt=6
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:49.855: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:49.855: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:56:49.867: S0/SU0/DS1-0/* new timeout is 1000
*Jun 5 13:56:49.867: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:49.867: mgcp_stw_timer_start timer type 0, duration 1000
*Jun 5 13:56:50.171: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:50.171: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089081,*msgp:0xC08A1828,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:0
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DA10,firstsent_ts:304,first_retx:1,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:56:50.171: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:50.171: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089081 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* retx msg again, retx_cnt=1
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* new timeout is 1000
*Jun 5 13:56:50.171: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:50.171: mgcp_stw_timer_start timer type 0, duration 1000
*Jun 5 13:56:51.155: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:51.155: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6B0F0,trans_id:529089079,*msgp:0x6663D980,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:5
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A1B0,firstsent_ts:16112,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
MGC1# S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:51.155: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:51.155: MGCP Packet sent to 172.18.150.80:2427--->
RM: restart
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* retx msg again, retx_cnt=6
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:51.155: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:51.155: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:56:51.167: %LINK-3-UPDOWN: Interface Serial0/0/1:15, changed state to down
*Jun 5 13:56:51.167: mgcp_check_subif_bind_state, bind type NONE
*Jun 5 13:56:51.175: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:51.175: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089080,*msgp:0x6663FC74,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:1
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6B110,firstsent_ts:1936,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:51.175: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:51.175: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* retx msg again, retx_cnt=2
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* new timeout is 2000
*Jun 5 13:56:51.175: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:51.175: mgcp_stw_timer_start timer type 0, duration 2000
*Jun 5 13:56:51.759: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:51.759: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089081,*msgp:0xC08A1828,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:1
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DA10,firstsent_ts:1892,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:56:51.759: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:51.759: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* retx msg again, retx_cnt=2
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* new timeout is 2000
*Jun 5 13:56:51.759: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:51.759: mgcp_stw_timer_start timer type 0, duration 2000
*Jun 5 13:56:52.815: mgcp_check_bind_state, bind type NONE
*Jun 5 13:56:53.055: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:53.055: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089080,*msgp:0x6663FC74,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:2
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6B110,firstsent_ts:3816,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:53.055: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:53.055: MGCP Packet sent to 172.18.150.80:2427--->
MGC1#RSIP 529089080 S0/SU0/DS1-0/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* retx msg again, retx_cnt=3
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:53.055: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:53.055: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:56:53.859: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:53.859: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089081,*msgp:0xC08A1828,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:2
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DA10,firstsent_ts:3992,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:56:53.859: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:53.859: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* retx msg again, retx_cnt=3
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* new timeout is 4000
*Jun 5 13:56:53.859: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:53.859: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:56:54.399: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:54.399: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:54.399: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:54.399: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6A190,trans_id:529089078,*msgp:0xC0C325C8,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:6
*Jun 5 13:56:54.399: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6AE80,firstsent_ts:20352,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:54.399: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:54.399: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:54.399: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:54.399: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
MGC1#
*Jun 5 13:56:54.399: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:54.399: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:54.399: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:54.399: mgcp_stw_timer_start timer type 0, duration 39648
*Jun 5 13:56:55.367: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:55.367: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:55.367: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:55.367: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6B0F0,trans_id:529089079,*msgp:0x6663D980,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:6
*Jun 5 13:56:55.367: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A1B0,firstsent_ts:20324,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:55.367: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:56:55.367: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:55.367: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:55.367: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:55.367: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:55.367: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:55.367: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:55.367: mgcp_stw_timer_start timer type 0, duration 39676
MGC1#
*Jun 5 13:56:56.811: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:56.811: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089080,*msgp:0x6663FC74,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:3
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6B110,firstsent_ts:7572,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:56:56.811: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:56.811: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* retx msg again, retx_cnt=4
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:56:56.811: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:56.811: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:56:57.327: mgcpapp_stw_call_back timer type 0
*Jun 5 13:56:57.327: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089081,*msgp:0xC08A1828,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:3
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DA10,firstsent_ts:7460,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:56:57.327: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:56:57.327: MGCP Packet sent to 172.18.150.80:2427--->
MGC1#RSIP 529089081 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* retx msg again, retx_cnt=4
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* new timeout is 4000
*Jun 5 13:56:57.327: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:56:57.327: mgcp_stw_timer_start timer type 0, duration 4000
MGC1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
MGC1(config)#
*Jun 5 13:57:00.831: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:00.831: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089080,*msgp:0x6663FC74,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:4
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6B110,firstsent_ts:11592,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:00.831: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:00.831: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* retx msg again, retx_cnt=5
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:57:00.831: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:00.831: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:57:01.251: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:01.251: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089081,*msgp:0xC08A1828,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:4
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DA10,firstsent_ts:11384,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:01.251: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:01.251: MGCP Packet sent to 172.18.150.80:2427--->
MGC1(config)#cRSIP 529089081 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* retx msg again, retx_cnt=5
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* new timeout is 4000
*Jun 5 13:57:01.251: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:01.251: mgcp_stw_timer_start timer type 0, duration 4000
MGC1(config)#contr
*Jun 5 13:57:03.055: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
MGC1(config)#contr logging buffered 100000
*Jun 5 13:57:04.851: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:04.851: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089080,*msgp:0x6663FC74,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:5
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6B110,firstsent_ts:15612,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:04.851: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:04.851: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* retx msg again, retx_cnt=6
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:57:04.851: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:04.851: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:57:05.271: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:05.271: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089081,*msgp:0xC08A1828,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:5
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DA10,firstsent_ts:15404,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:05.271: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:05.271: MGCP Packet sent to 172.18.150.80:2427--->
MGC1(config)#logging buffered 100000RSIP 529089081 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* retx msg again, retx_cnt=6
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* new timeout is 4000
*Jun 5 13:57:05.271: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:05.271: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:57:08.871: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:08.871: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089080,*msgp:0x6663FC74,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:6
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6B110,firstsent_ts:19632,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:08.871: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:08.871: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* retx msg again, retx_cnt=7
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:57:08.871: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:08.871: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:57:09.291: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:09.291: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089081,*msgp:0xC08A1828,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:6
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DA10,firstsent_ts:19424,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:09.291: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:09.291: MGCP Packet sent to 172.18.150.80:2427--->
MGC1(config)#lo cRSIP 529089081 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* retx msg again, retx_cnt=7
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* new timeout is 4000
*Jun 5 13:57:09.291: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:09.291: mgcp_stw_timer_start timer type 0, duration 4000
MGC1(config)#controll
MGC1(config)#controller
*Jun 5 13:57:12.891: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:12.891: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:12.891: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:12.891: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089080,*msgp:0x6663FC74,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:7
*Jun 5 13:57:12.891: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6B110,firstsent_ts:23652,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:12.891: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:12.891: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:12.891: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:12.891: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:12.891: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:12.891: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:12.891: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:12.891: mgcp_stw_timer_start timer type 0, duration 36348
*Jun 5 13:57:12.971: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/mgc1.cfg) failed
*Jun 5 13:57:13.311: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:13.311: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:13.311: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:57:13.311: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089081,*msgp:0xC08A1828,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:7
*Jun 5 13:57:13.311: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DA10,firstsent_ts:23444,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:13.311: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:13.311: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:57:13.311: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:13.311: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
MGC1(config)#controller e1
*Jun 5 13:57:13.311: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:13.311: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:13.311: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:13.311: mgcp_stw_timer_start timer type 0, duration 36556
MGC1(config)#controller e1 0/0/0
MGC1(config-controller)#n shut
MGC1(config-controller)#no s
*Jun 5 13:57:21.519: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to administratively down
MGC1(config-controller)#no shut
*Jun 5 13:57:23.055: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure with the Power System 1 or this Power System has been turned off.
*Jun 5 13:57:23.519: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to down
*Jun 5 13:57:23.519: mgcp_check_subif_bind_state, bind type NONE
*Jun 5 13:57:27.127: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
*Jun 5 13:57:27.127: mgcp_app_info_about_port_update: vdbptr = C0A99C30
*Jun 5 13:57:27.127: mgcp_app_info_about_port_update: vdbptr C0A99C30, slot 0, ctrl no 0, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:57:27.127: MGCP sys msg: (5)
*Jun 5 13:57:27.127: xlate sys msg: (5, C0873A54)
*Jun 5 13:57:27.127: sys msg values: (INVALID MGCP EVENT, 0, , 1648912992, CALL_IDLE)
*Jun 5 13:57:27.127: mgcp_interface_new_ds0_grp: vdbptr C0A99C30, slot 0, ctrl no 0, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE
*Jun 5 13:57:27.127: xgcp_endpt_create_dsx ts_bitmap: FFFEFFFE
*Jun 5 13:57:27.127: xgcp_endpt_create_dsx ds1_state: 2
*Jun 5 13:57:27.127: xgcp_endpt_get_by_ifn
*Jun 5 13:57:27.127: xgcp_endpt_get_dsx_by_ifn
*Jun 5 13:57:27.127: xgcp_endpt_get_tree_link_by_ifn
*Jun 5 13:57:27.127: xgcp_endpt_compute_key- type 0 slot 0000 subunit 0000
*Jun 5 13:57:27.127: xgcp_endpt_get_tree_link_by_ifn : computed key 0x00000000
*Jun 5 13:57:27.127: xgcp_endpt_get_ds0_group_from_ds1 endpt S0/SU0/DS1-0/*
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcpapp_rsip_ds0_grp_up:vdbptr = C0A99C30
*Jun 5 13:57:27.127: xgcp_endpt_get_state endpt S0/SU0/DS1-0/*
*Jun 5 13:57:27.127: xgcp_endpt_default_get_state endpt S0/SU0/DS1-0/*
*Jun 5 13:57:27.127: mgcp_ds0_group_state_change: state=2
*Jun 5 13:57:27.127: mgcp_ds0_group_set_ds0_states
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/15
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/15
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/18
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/18
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/26
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/26
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/27
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/27
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/28
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/28
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/29
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/29
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/30
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/30
*Jun 5 13:57:27.127: xgcp_endpt_set_state endpt S0/SU0/DS1-0/31
*Jun 5 13:57:27.127: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/31
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_ds0_group_rsip:
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_ds1_max_timeslots: max_ts_bitmap FFFEFFFE ts_bitmap FFFEFFFE
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_individual_rsips_required:
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_endpt_rsip_required: restart_method=3, state=2
*Jun 5 13:57:27.127: mgcp_reconcile_rsip_method_and_state restart_method=3, state=2
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_send_rsip_to_mgc: restart_method=3, rsip_shutdown=0
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:27.127: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* Sending RSIP to (172.18.150.80) Notify entity (172.18.150.80)
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_send_rsip_msg:
*Jun 5 13:57:27.127: -- mgcp_build_packet()-
*Jun 5 13:57:27.127: - mgcp_estimate_msg_buf_length() - 328 bytes needed for header
- mgcp_estimate_msg_buf_length() - 344 bytes needed after checking parameter lines
- mgcp_estimate_msg_buf_length() - 344 bytes needed after cheking SDP lines
*Jun 5 13:57:27.127: --- mgcp_build_parameter_lines() ---
- mgcp_val_mandatory_parms()
- mgcp_build_restart_method() is called
- SUCCESS: Building Restart Method (RM:) OK
- SUCCESS: Building MGCP Parameter lines is OK
*Jun 5 13:57:27.127: - SUCCESS: MGCP message building OK
*Jun 5 13:57:27.127: - SUCCESS: END of building
*Jun 5 13:57:27.127: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089082 S0/SU0/DS1-0/*@MGC1 MGCP 0.1
RM: restart
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_endpt_record_rsip:
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_send_rsip_msg: Manually recroding RSIP method
*Jun 5 13:57:27.127: S0/SU0/DS1-0/* mgcp_enq_retx_rsip_msg
*Jun 5 13:57:27.127: mgcp_add_trans_id_rec: Add trans id (529089082, C0D6DC80) record
*Jun 5 13:57:27.127: mgcp_stw_timer_start timer type 0, duration 500
*Jun 5 13:57:27.127: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:27.127: ISDN Se0/0/0:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:27.631: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:27.631: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089082,*msgp:0x665D413C,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:0
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DCA0,firstsent_ts:504,first_retx:1,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:27.631: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:27.631: MGCP Packet sent to 172.18.150.80:2427--->
RM: restart
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* retx msg again, retx_cnt=1
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* new timeout is 1000
*Jun 5 13:57:27.631: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:27.631: mgcp_stw_timer_start timer type 0, duration 1000
*Jun 5 13:57:27.875: %CONTROLLER-5-UPDOWN: Controller E1 0/0/1, changed state to up
*Jun 5 13:57:27.875: mgcp_app_info_about_port_update: vdbptr = 70BE6CB0
*Jun 5 13:57:27.875: mgcp_app_info_about_port_update: vdbptr 70BE6CB0, slot 0, ctrl no 1, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:57:27.875: MGCP sys msg: (5)
*Jun 5 13:57:27.875: xlate sys msg: (5, C0873A68)
*Jun 5 13:57:27.875: sys msg values: (INVALID MGCP EVENT, 0, , 1648912992, CALL_IDLE)
*Jun 5 13:57:27.875: mgcp_interface_new_ds0_grp: vdbptr 70BE6CB0, slot 0, ctrl no 1, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE
*Jun 5 13:57:27.875: xgcp_endpt_create_dsx ts_bitmap: FFFEFFFE
*Jun 5 13:57:27.875: xgcp_endpt_create_dsx ds1_state: 2
*Jun 5 13:57:27.875: xgcp_endpt_get_by_ifn
*Jun 5 13:57:27.875: xgcp_endpt_get_dsx_by_ifn
*Jun 5 13:57:27.875: xgcp_endpt_get_tree_link_by_ifn
*Jun 5 13:57:27.875: xgcp_endpt_compute_key- type 0 slot 0000 subunit 0000
*Jun 5 13:57:27.875: xgcp_endpt_get_tree_link_by_ifn : computed key 0x00000001
*Jun 5 13:57:27.875: xgcp_endpt_get_ds0_group_from_ds1 endpt S0/SU0/DS1-1/*
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcpapp_rsip_ds0_grp_up:vdbptr = 70BE6CB0
*Jun 5 13:57:27.875: xgcp_endpt_get_state endpt S0/SU0/DS1-1/*
*Jun 5 13:57:27.875: xgcp_endpt_default_get_state endpt S0/SU0/DS1-1/*
*Jun 5 13:57:27.875: mgcp_ds0_group_state_change: state=2
*Jun 5 13:57:27.875: mgcp_ds0_group_set_ds0_states
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/1
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/1
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/2
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/2
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/3
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/3
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/4
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/4
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/5
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/5
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/6
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/6
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/7
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/7
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/8
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/8
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/9
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/9
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/10
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/10
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/11
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/11
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/12
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/12
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/13
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/13
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/14
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/14
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/15
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/15
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/17
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/17
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/18
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/18
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/19
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/19
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/20
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/20
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/21
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/21
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/22
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/22
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/23
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/23
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/24
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/24
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/25
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/25
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/26
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/26
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/27
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/27
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/28
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/28
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/29
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/29
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/30
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/30
*Jun 5 13:57:27.875: xgcp_endpt_set_state endpt S0/SU0/DS1-1/31
*Jun 5 13:57:27.875: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/31
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_ds0_group_rsip:
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_ds1_max_timeslots: max_ts_bitmap FFFEFFFE ts_bitmap FFFEFFFE
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_individual_rsips_required:
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_endpt_rsip_required: restart_method=3, state=2
*Jun 5 13:57:27.875: mgcp_reconcile_rsip_method_and_state restart_method=3, state=2
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_send_rsip_to_mgc: restart_method=3, rsip_shutdown=0
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:57:27.875: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* Sending RSIP to (172.18.150.80) Notify entity (172.18.150.80)
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_send_rsip_msg:
*Jun 5 13:57:27.875: -- mgcp_build_packet()-
*Jun 5 13:57:27.875: - mgcp_estimate_msg_buf_length() - 328 bytes needed for header
*Jun 5 13:57:27.875: --- mgcp_build_parameter_lines() ---
*Jun 5 13:57:27.875: - SUCCESS: MGCP message building OK
*Jun 5 13:57:27.875: - SUCCESS: END of building
*Jun 5 13:57:27.875: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089083 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: restart
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_endpt_record_rsip:
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_send_rsip_msg: Manually recroding RSIP method
*Jun 5 13:57:27.875: S0/SU0/DS1-1/* mgcp_enq_retx_rsip_msg
*Jun 5 13:57:27.875: mgcp_add_trans_id_rec: Add trans id (529089083, C0D6A420) record
*Jun 5 13:57:27.875: mgcp_stw_timer_start timer type 0, duration 500
*Jun 5 13:57:27.879: ISDN Se0/0/1:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:27.879: ISDN Se0/0/1:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:28.287: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:28.287: ISDN Se0/0/0:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:28.391: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:28.391: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089083,*msgp:0xC0EEFA00,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:0
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A440,firstsent_ts:516,first_retx:1,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:28.391: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:28.391: MGCP Packet sent to 172.18.150.80:2427--->
RM: restart
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* retx msg again, retx_cnt=1
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* new timeout is 1000
*Jun 5 13:57:28.391: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:28.391: mgcp_stw_timer_start timer type 0, duration 1000
*Jun 5 13:57:28.891: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:28.891: ISDN Se0/0/1:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:28.891: ISDN Se0/0/1:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:28.891: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:28.891: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:28.891: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089082,*msgp:0x665D413C,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:1
*Jun 5 13:57:28.891: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DCA0,firstsent_ts:1764,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:28.895: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:28.895: MGCP Packet sent to 172.18.150.80:2427--->
RM: restart
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* retx msg again, retx_cnt=2
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* new timeout is 2000
*Jun 5 13:57:28.895: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:28.895: mgcp_stw_timer_start timer type 0, duration 2000
*Jun 5 13:57:29.275: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to up
*Jun 5 13:57:29.275: mgcp_check_subif_bind_state, bind type NONE
*Jun 5 13:57:29.959: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:29.959: ISDN Se0/0/0:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:29.959: ISDN Se0/0/1:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:29.959: ISDN Se0/0/1:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:29.959: %CONTROLLER-5-UPDOWN: Controller E1 0/0/1, changed state to down (LOF detected)
*Jun 5 13:57:29.959: mgcp_app_info_about_port_update: vdbptr = 70BE6CB0
*Jun 5 13:57:29.959: mgcp_app_info_about_port_update: vdbptr 70BE6CB0, slot 0, ctrl no 1, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:57:29.983: %LINK-3-UPDOWN: Interface Serial0/0/1:15, changed state to up
*Jun 5 13:57:29.983: mgcp_check_subif_bind_state, bind type NONE
*Jun 5 13:57:29.983: MGCP sys msg: (6)
*Jun 5 13:57:29.983: xlate sys msg: (6, C0873A7C)
*Jun 5 13:57:29.983: sys msg values: (INVALID MGCP EVENT, 0, , 1648912992, CALL_IDLE)
*Jun 5 13:57:29.983: mgcp_interface_rem_ds0_grp: slot 0, ctrl no=1, timeslots=4294901758, vdb=70BE6CB0
*Jun 5 13:57:29.983: xgcp_endpt_get_by_ifn
*Jun 5 13:57:29.983: xgcp_endpt_get_dsx_by_ifn
*Jun 5 13:57:29.983: xgcp_endpt_get_tree_link_by_ifn
*Jun 5 13:57:29.983: xgcp_endpt_compute_key- type 0 slot 0000 subunit 0000
*Jun 5 13:57:29.983: xgcp_endpt_get_tree_link_by_ifn : computed key 0x00000001
*Jun 5 13:57:29.983: xgcp_endpt_set_state endpt S0/SU0/DS1-1/*
*Jun 5 13:57:29.983: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/*
*Jun 5 13:57:29.983: S0/SU0/DS1-1/* mgcpapp_rsip_ds0_grp_down vdbptr = 70BE6CB0
*Jun 5 13:57:29.983: xgcp_endpt_get_ds0_group_from_ds1 endpt S0/SU0/DS1-1/*
*Jun 5 13:57:29.983: S0/SU0/DS1-1/* mgcp_default_gw_dlcx:
*Jun 5 13:57:29.983: xgcp_endpt_get_first
*Jun 5 13:57:29.983: xgcp_endpt_get_first_child endpt S0/SU0/DS1-1/*
*Jun 5 13:57:29.983: xgcp_endpt_ds1_get_first_child endpt S0/SU0/DS1-1/*
*Jun 5 13:57:29.983: S0/SU0/DS1-1/1 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: mgcp_delete_req_digit_filter_q
*Jun 5 13:57:29.983: mgcp_delete_qb_evt_q:cleanup QB evt q
*Jun 5 13:57:29.983: xgcp_endpt_get_next
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/1
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/1
*Jun 5 13:57:29.983: S0/SU0/DS1-1/2 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/2
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/2
*Jun 5 13:57:29.983: S0/SU0/DS1-1/3 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/3
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/3
*Jun 5 13:57:29.983: S0/SU0/DS1-1/4 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/4
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/4
*Jun 5 13:57:29.983: S0/SU0/DS1-1/5 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/5
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/5
*Jun 5 13:57:29.983: S0/SU0/DS1-1/6 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/6
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/6
*Jun 5 13:57:29.983: S0/SU0/DS1-1/7 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/7
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/7
*Jun 5 13:57:29.983: S0/SU0/DS1-1/8 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/8
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/8
*Jun 5 13:57:29.983: S0/SU0/DS1-1/9 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/9
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/9
*Jun 5 13:57:29.983: S0/SU0/DS1-1/10 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/10
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/10
*Jun 5 13:57:29.983: S0/SU0/DS1-1/11 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.983: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/11
*Jun 5 13:57:29.983: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/11
*Jun 5 13:57:29.983: S0/SU0/DS1-1/12 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_next
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/12
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/12
*Jun 5 13:57:29.987: S0/SU0/DS1-1/13 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: mgcp_delete_req_digit_filter_q
*Jun 5 13:57:29.987: mgcp_delete_qb_evt_q:cleanup QB evt q
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/13
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/13
*Jun 5 13:57:29.987: S0/SU0/DS1-1/14 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/14
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/14
*Jun 5 13:57:29.987: S0/SU0/DS1-1/15 mgcp_fs_gw_dlcx
*Ju
MGC1(config-controller)#n 5 13:57:29.987: xgcp_endpt_get_next
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/15
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/15
*Jun 5 13:57:29.987: S0/SU0/DS1-1/17 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/17
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/17
*Jun 5 13:57:29.987: S0/SU0/DS1-1/18 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/18
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/18
*Jun 5 13:57:29.987: S0/SU0/DS1-1/19 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/19
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/19
*Jun 5 13:57:29.987: S0/SU0/DS1-1/20 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/20
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/20
*Jun 5 13:57:29.987: S0/SU0/DS1-1/21 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/21
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/21
*Jun 5 13:57:29.987: S0/SU0/DS1-1/22 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/22
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/22
*Jun 5 13:57:29.987: S0/SU0/DS1-1/23 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/23
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/23
*Jun 5 13:57:29.987: S0/SU0/DS1-1/24 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/24
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/24
*Jun 5 13:57:29.987: S0/SU0/DS1-1/25 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/25
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/25
*Jun 5 13:57:29.987: S0/SU0/DS1-1/26 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/26
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/26
*Jun 5 13:57:29.987: S0/SU0/DS1-1/27 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/27
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/27
*Jun 5 13:57:29.987: S0/SU0/DS1-1/28 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/28
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/28
*Jun 5 13:57:29.987: S0/SU0/DS1-1/29 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/29
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/29
*Jun 5 13:57:29.987: S0/SU0/DS1-1/30 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/30
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/30
*Jun 5 13:57:29.987: S0/SU0/DS1-1/31 mgcp_fs_gw_dlcx
*Jun 5 13:57:29.987: xgcp_endpt_get_sibling endpt S0/SU0/DS1-1/31
*Jun 5 13:57:29.987: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-1/31
*Jun 5 13:57:29.987: mgcp_ds0_group_state_change: state=1
*Jun 5 13:57:29.987: mgcp_ds0_group_set_ds0_states
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/1
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/1
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/2
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/2
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/3
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/3
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/4
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/4
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/5
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/5
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/6
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/6
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/7
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/7
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/8
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/8
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/9
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/9
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/10
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/10
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/11
MGC1(config-controller)#set_state endpt S0/SU0/DS1-1/11
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/12
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/12
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/13
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/13
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/14
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/14
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/15
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/15
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/17
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/17
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/18
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/18
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/19
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/19
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/20
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/20
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/21
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/21
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/22
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/22
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/23
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/23
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/24
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/24
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/25
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/25
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/26
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/26
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/27
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/27
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/28
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/28
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/29
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/29
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/30
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/30
*Jun 5 13:57:29.987: xgcp_endpt_set_state endpt S0/SU0/DS1-1/31
*Jun 5 13:57:29.987: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/31
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_ds0_group_rsip:
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_ds1_max_timeslots: max_ts_bitmap FFFEFFFE ts_bitmap FFFEFFFE
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_individual_rsips_required:
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_endpt_rsip_required: restart_method=1, state=1
*Jun 5 13:57:29.987: mgcp_reconcile_rsip_method_and_state restart_method=1, state=1
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_send_rsip_to_mgc: restart_method=1, rsip_shutdown=0
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:57:29.987: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* Sending RSIP to (172.18.150.80) Notify entity (172.18.150.80)
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_send_rsip_msg:
*Jun 5 13:57:29.987: -- mgcp_build_packet()-
*Jun 5 13:57:29.987: - mgcp_estimate_msg_buf_length() - 328 bytes needed for header
- mgcp_estimate_msg_buf_length() - 360 bytes needed after checking parameter lines
- mgcp_estimate_msg_buf_length() - 360 bytes needed after cheking SDP lines
*Jun 5 13:57:29.987: --- mgcp_build_parameter_lines() ---
- mgcp_build_restart_delay() is called
*Jun 5 13:57:29.987: - SUCCESS: MGCP message building OK
*Jun 5 13:57:29.987: - SUCCESS: END of building
*Jun 5 13:57:29.987: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089084 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_endpt_record_rsip:
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_send_rsip_msg: Manually recroding RSIP method
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_enq_retx_rsip_msg
*Jun 5 13:57:29.987: mgcp_add_trans_id_rec: Add trans id (529089084, C0D6A6B0) record
*Jun 5 13:57:29.987: mgcp_stw_timer_start timer type 0, duration 500
*Jun 5 13:57:29.987: S0/SU0/DS1-1/* mgcp_ds0_group_reset_voice_caps
*Jun 5 13:57:29.991: ISDN Se0/0/1:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:29.991: %ISDN-4-ISDN_UNEXPECTED_EVENT: Se0/0/1:15: Occurred at ../isdn/isdnif_proc.c:1394
*Jun 5 13:57:29.991: ISDN Se0/0/1:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Jun 5 13:57:29.991: ISDN Se0/0/1:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
*Jun 5 13:57:29.991: ISDN Se0/0/1:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:29.991: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:29.991: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:29.991: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:57:29.991: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0xC0D6A6B0,trans_id:529089083,*msgp:0xC0EEFA00,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:1
*Jun 5 13:57:29.991: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A440,firstsent_ts:2116,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1RSIP 529089084 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:57:30.139: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:30.139: S0/SU0/DS1-1/* retx msg again, retx_cnt=1
*Jun 5 13:57:30.139: S0/SU0/DS1-1/* new timeout is 1000
*Jun 5 13:57:30.139: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:30.139: mgcp_stw_timer_start timer type 0, duration 1000
*Jun 5 13:57:30.139: mgcp_check_bind_state, bind type NONE
*Jun 5 13:57:31.343: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:31.343: ISDN Se0/0/0:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:31.343: ISDN Se0/0/0:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:31.343: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089082,*msgp:0x665D413C,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:2
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DCA0,firstsent_ts:4216,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:31.343: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:31.343: MGCP Packet sent to 172.18.150.80:2427--->
RM: restart
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* retx msg again, retx_cnt=3
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:57:31.343: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:31.343: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:57:31.347: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected)
*Jun 5 13:57:31.347: mgcp_app_info_about_port_update: vdbptr = C0A99C30
*Jun 5 13:57:31.347: mgcp_app_info_about_port_update: vdbptr C0A99C30, slot 0, ctrl no 0, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:57:31.359: mgcp_check_bind_state, bind type NONE
*Jun 5 13:57:31.359: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to down
*Jun 5 13:57:31.359: mgcp_check_subif_bind_state, bind type NONE
*Jun 5 13:57:31.367: MGCP sys msg: (6)
*Jun 5 13:57:31.367: xlate sys msg: (6, C0873A90)
*Jun 5 13:57:31.367: sys msg values: (INVALID MGCP EVENT, 0, , 1648912992, CALL_IDLE)
*Jun 5 13:57:31.367: mgcp_interface_rem_ds0_grp: slot 0, ctrl no=0, timeslots=4294901758, vdb=C0A99C30
*Jun 5 13:57:31.367: xgcp_endpt_get_by_ifn
*Jun 5 13:57:31.367: xgcp_endpt_get_dsx_by_ifn
*Jun 5 13:57:31.367: xgcp_endpt_get_tree_link_by_ifn
*Jun 5 13:57:31.367: xgcp_endpt_compute_key- type 0 slot 0000 subunit 0000
*Jun 5 13:57:31.367: xgcp_endpt_get_tree_link_by_ifn : computed key 0x00000000
*Jun 5 13:57:31.367: xgcp_endpt_set_state endpt S0/SU0/DS1-0/*
*Jun 5 13:57:31.367: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/*
*Jun 5 13:57:31.367: S0/SU0/DS1-0/* mgcpapp_rsip_ds0_grp_down vdbptr = C0A99C30
*Jun 5 13:57:31.367: xgcp_endpt_get_ds0_group_from_ds1 endpt S0/SU0/DS1-0/*
*Jun 5 13:57:31.367: S0/SU0/DS1-0/* mgcp_default_gw_dlcx:
*Jun 5 13:57:31.367: xgcp_endpt_get_first
*Jun 5 13:57:31.367: xgcp_endpt_get_first_child endpt S0/SU0/DS1-0/*
*Jun 5 13:57:31.367: xgcp_endpt_ds1_get_first_child endpt S0/SU0/DS1-0/*
*Jun 5 13:57:31.367: S0/SU0/DS1-0/1 mgcp_fs_gw_dlcx
MGC1(config-controller)#7D80, signal list=70CA7498
*Jun 5 13:57:31.367: mgcp_delete_req_digit_filter_q
*Jun 5 13:57:31.367: mgcp_delete_qb_evt_q:cleanup QB evt q
*Jun 5 13:57:31.367: xgcp_endpt_get_next
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/1
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/1
*Jun 5 13:57:31.367: S0/SU0/DS1-0/2 mgcp_fs_gw_dlcx
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/2
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/2
*Jun 5 13:57:31.367: S0/SU0/DS1-0/3 mgcp_fs_gw_dlcx
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/3
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/3
*Jun 5 13:57:31.367: S0/SU0/DS1-0/4 mgcp_fs_gw_dlcx
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/4
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/4
*Jun 5 13:57:31.367: S0/SU0/DS1-0/5 mgcp_fs_gw_dlcx
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/5
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/5
*Jun 5 13:57:31.367: S0/SU0/DS1-0/6 mgcp_fs_gw_dlcx
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/6
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/6
*Jun 5 13:57:31.367: S0/SU0/DS1-0/7 mgcp_fs_gw_dlcx
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/7
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/7
*Jun 5 13:57:31.367: S0/SU0/DS1-0/8 mgcp_fs_gw_dlcx
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/8
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/8
*Jun 5 13:57:31.367: S0/SU0/DS1-0/9 mgcp_fs_gw_dlcx
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/9
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/9
*Jun 5 13:57:31.367: S0/SU0/DS1-0/10 mgcp_fs_gw_dlcx
*Jun 5 13:57:31.367: xgcp_endpt_get_sibling endpt S0/SU0/DS1-0/10
*Jun 5 13:57:31.367: xgcp_endpt_ds0_get_sibling endpt S0/SU0/DS1-0/10
*Jun 5 13:57:31.367: S0/SU0/DS1-0/11 mgcp_fs_gw_dlcxRSIP 529089083 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: restart
*Jun 5 13:57:31.923: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:31.923: S0/SU0/DS1-1/* retx msg again, retx_cnt=3
*Jun 5 13:57:31.923: S0/SU0/DS1-1/* new timeout is 4000
*Jun 5 13:57:31.923: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:31.923: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:57:32.867: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:32.867: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089085,*msgp:0xC0EF1234,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:1
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A960,firstsent_ts:1496,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:32.867: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:32.867: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089085 S0/SU0/DS1-0/*@MGC1 MGCP 0.1
RM: graceful
RD: 0
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* retx msg again, retx_cnt=2
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* new timeout is 2000
*Jun 5 13:57:32.867: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:32.867: mgcp_stw_timer_start timer type 0, duration 2000
*Jun 5 13:57:33.251: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:33.251: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089084,*msgp:0xC0EF0CC0,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:2
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A6D0,firstsent_ts:3264,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:33.251: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:33.251: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* retx msg again, retx_cnt=3
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* new timeout is 4000
*Jun 5 13:57:33.251: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:33.2
MGC1(config-controller)#51: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:57:33.879: %CONTROLLER-5-UPDOWN: Controller E1 0/0/1, changed state to up
*Jun 5 13:57:33.879: mgcp_app_info_about_port_update: vdbptr = 70BE6CB0
*Jun 5 13:57:33.879: mgcp_app_info_about_port_update: vdbptr 70BE6CB0, slot 0, ctrl no 1, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:57:33.883: MGCP sys msg: (5)
*Jun 5 13:57:33.883: xlate sys msg: (5, C0873AA4)
*Jun 5 13:57:33.883: sys msg values: (INVALID MGCP EVENT, 0, , 1648912992, CALL_IDLE)
*Jun 5 13:57:33.883: mgcp_interface_new_ds0_grp: vdbptr 70BE6CB0, slot 0, ctrl no 1, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE
*Jun 5 13:57:33.883: xgcp_endpt_create_dsx ts_bitmap: FFFEFFFE
*Jun 5 13:57:33.883: xgcp_endpt_create_dsx ds1_state: 2
*Jun 5 13:57:33.883: xgcp_endpt_get_by_ifn
*Jun 5 13:57:33.883: xgcp_endpt_get_dsx_by_ifn
*Jun 5 13:57:33.883: xgcp_endpt_get_tree_link_by_ifn
*Jun 5 13:57:33.883: xgcp_endpt_compute_key- type 0 slot 0000 subunit 0000
*Jun 5 13:57:33.883: xgcp_endpt_get_tree_link_by_ifn : computed key 0x00000001
*Jun 5 13:57:33.883: xgcp_endpt_get_ds0_group_from_ds1 endpt S0/SU0/DS1-1/*
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcpapp_rsip_ds0_grp_up:vdbptr = 70BE6CB0
*Jun 5 13:57:33.883: xgcp_endpt_get_state endpt S0/SU0/DS1-1/*
*Jun 5 13:57:33.883: xgcp_endpt_default_get_state endpt S0/SU0/DS1-1/*
*Jun 5 13:57:33.883: mgcp_ds0_group_state_change: state=2
*Jun 5 13:57:33.883: mgcp_ds0_group_set_ds0_states
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/1
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/1
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/2
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/2
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/3
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/3
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/4
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/4
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/5
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/5
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/6
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/6
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/7
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/7
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/8
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/8
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/9
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/9
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/10
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/10
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/11
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/11
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/12
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/12
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/13
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/13
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/14
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/14
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/15
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/15
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/17
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/17
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/18
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/18
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/19
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/19
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/20
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/20
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/21
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/21
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/22
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/22
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/23
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/23
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/24
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/24
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/25
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/25
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/26
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/26
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/27
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/27
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/28
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/28
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/29
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/29
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/30
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/30
*Jun 5 13:57:33.883: xgcp_endpt_set_state endpt S0/SU0/DS1-1/31
*Jun 5 13:57:33.883: xgcp_endpt_default_set_state endpt S0/SU0/DS1-1/31
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_ds0_group_rsip:
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_ds1_max_timeslots: max_ts_bitmap FFFEFFFE ts_bitmap FFFEFFFE
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_individual_rsips_required:
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_endpt_rsip_required: restart_method=3, state=2
*Jun 5 13:57:33.883: mgcp_reconcile_rsip_method_and_state restart_method=3, state=2
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_send_rsip_to_mgc: restart_method=3, rsip_shutdown=0
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:57:33.883: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* Sending RSIP to (172.18.150.80) Notify entity (172.18.150.80)
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_send_rsip_msg:
*Jun 5 13:57:33.883: -- mgcp_build_packet()-
*Jun 5 13:57:33.883: - mgcp_estimate_msg_buf_length() - 328 bytes needed for header
*Jun 5 13:57:33.883: --- mgcp_build_parameter_lines() ---
*Jun 5 13:57:33.883: - SUCCESS: MGCP message building OK
*Jun 5 13:57:33.883: - SUCCESS: END of building
*Jun 5 13:57:33.883: MGCP Packet sent to 172.18.150.80:2427--->
RSIP 529089086 S0/SU0/DS1-1/*@MGC1 MGCP 0.1
RM: restart
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_endpt_record_rsip:
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_send_rsip_msg: Manually recroding RSIP method
*Jun 5 13:57:33.883: S0/SU0/DS1-1/* mgcp_enq_retx_rsip_msg
*Jun 5 13:57:33.883: mgcp_add_trans_id_rec: Add trans id (529089086, C0D6DF10) record
*Jun 5 13:57:33.883: mgcp_stw_timer_start timer type 0, duration 500
*Jun 5 13:57:33.883: ISDN Se0/0/1:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:33.883: ISDN Se0/0/1:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:34.715: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:34.715: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089085,*msgp:0xC0EF1234,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:2
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6A960,firstsent_ts:3344,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:34.715: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:34.715: MGCP Packet sent to 172.18.150.80:2427--->
RM: graceful
RD: 0
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* retx msg again, retx_cnt=3
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:57:34.715: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:34.715: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_retx_msg
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,*next:0x00000000,trans_id:529089086,*msgp:0xC098BC28,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:0
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DF30,firstsent_ts:832,first_retx:1,is_restar
MGC1(config-controller)#t_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-1/*,*endpt:0x651D1B54
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_default_get_configured_ca:
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_ds1_get_profile:
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
RM: restart
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* retx msg again, retx_cnt=1
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* new timeout is 1000
*Jun 5 13:57:34.715: S0/SU0/DS1-1/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:34.715: mgcp_stw_timer_start timer type 0, duration 1000
*Jun 5 13:57:35.371: mgcpapp_stw_call_back timer type 0
*Jun 5 13:57:35.375: ISDN Se0/0/1:15 **ERROR**: L2IF_SendPkt: idb is NULL
*Jun 5 13:57:35.375: ISDN Se0/0/1:15 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
*Jun 5 13:57:35.375: mgcpapp_process_timers: timer of type 0 expired.
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6A940,trans_id:529089082,*msgp:0x665D413C,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:3
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6DCA0,firstsent_ts:8248,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:15,*dns_request:0x00000000
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,notify_entity:172.18.150.80,raddr_sec_info[0]:0.0.0.0,raddr_sec_info[1]:0.0.0.0,used_ip_addr[0]:0.0.0.0,used_ip_addr[1]:0.0.0.0,used_ip_addr_index:0,endpt_name:S0/SU0/DS1-0/*,*endpt:0x66638AFC
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_endpt_get_notified_entity:
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_default_get_configured_ca:
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_ds1_get_profile:
*Jun 5 13:57:35.375: mgcp_get_active_ccm_ip_addr: Using actv CCM IP addr 172.18.150.80, port 2427, ntfy entity 172.18.150.80
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_default_get_configured_ca: profile NE 172.18.150.80 (172.18.150.80:2427)
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg:max2 no of retries kicks in
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg:DNS Lookup Stat=1
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_send_piggyback_msg:to raddr=172.18.150.80,rport=2427 fromladdr=0.0.0.0,lport = 2427
*Jun 5 13:57:35.375: MGCP Packet sent to 172.18.150.80:2427--->
RM: restart
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_send_piggyback_msg: SUCCESSFUL retransmission
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* retx msg again, retx_cnt=4
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* new timeout is 4000
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg:Starting retx again
*Jun 5 13:57:35.375: mgcp_stw_timer_start timer type 0, duration 4000
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,*next:0xC0D6A190,trans_id:529089078,*msgp:0xC0C325C8,laddr:0.0.0.0,raddr_info:172.18.150.80,activ_ca_addr:0.0.0.0,raddr_secondary_index:0,lport:2427,rport:2427,retx_cnt:6
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,timer:0xC0D6AE80,firstsent_ts:61328,first_retx:0,is_restart_rsip:0,prot_ver:4,*profile:0x64ED4B74,wait_def_mgc_ack:1,rsip_shutdown:0,rqnt_ack:0,dns_lookup_stat:1
*Jun 5 13:57:35.375: S0/SU0/DS1-0/* mgcp_retx_msg - retx_recp->,msg_type:8,last_ntfy_trans_id:0,max1_lookup:1,max1_retry:5,max2_lookup:1,max2_retry:7,timeout_thist:30000,timeout_tsmax:20000,timeout_tdinit:0,*dns_request:0x00000000
*Jun 5 13:57:35.387: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
*Jun 5 13:57:35.387: mgcp_app_info_about_port_update: vdbptr = C0A99C30
*Jun 5 13:57:35.387: mgcp_app_info_about_port_update: vdbptr C0A99C30, slot 0, ctrl no 0, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:57:35.387: %CONTROLLER-5-UPDOWN: Controller E1 0/0/1, changed state to down (LOF detected)
*Jun 5 13:57:35.387: mgcp_app_info_about_port_update: vdbptr = 70BE6CB0
*Jun 5 13:57:35.387: mgcp_app_info_about_port_update: vdbptr 70BE6CB0, slot 0, ctrl no 1, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE, ctrlr_ev 1
*Jun 5 13:57:35.391: MGCP sys msg: (5)
*Jun 5 13:57:35.391: xlate sys msg: (5, C0873AB8)
*Jun 5 13:57:35.391: sys msg values: (INVALID MGCP EVENT, 0, , 1648912992, CALL_IDLE)
*Jun 5 13:57:35.391: mgcp_interface_new_ds0_grp: vdbptr C0A99C30, slot 0, ctrl no 0, ts_bitmap FFFEFFFE, max_ts_bitmap FFFEFFFE
*Jun 5 13:57:35.391: xgcp_endpt_create_dsx ts_bitmap: FFFEFFFE
*Jun 5 13:57:35.391: xgcp_endpt_create_dsx ds1_state: 2
*Jun 5 13:57:35.391: xgcp_endpt_get_by_ifn
*Jun 5 13:57:35.391: xgcp_endpt_get_dsx_by_ifn
*Jun 5 13:57:35.391: xgcp_endpt_get_tree_link_by_ifn
*Jun 5 13:57:35.391: xgcp_endpt_compute_key- type 0 slot 0000 subunit 0000
*Jun 5 13:57:35.391: xgcp_endpt_get_tree_link_by_ifn : computed key 0x00000000
*Jun 5 13:57:35.391: xgcp_endpt_get_ds0_group_from_ds1 endpt S0/SU0/DS1-0/*
*Jun 5 13:57:35.391: S0/SU0/DS1-0/* mgcpapp_rsip_ds0_grp_up:vdbptr = C0A99C30
*Jun 5 13:57:35.391: xgcp_endpt_get_state endpt S0/SU0/DS1-0/*
*Jun 5 13:57:35.391: xgcp_endpt_default_get_state endpt S0/SU0/DS1-0/*
*Jun 5 13:57:35.391: mgcp_ds0_group_state_change: state=2
*Jun 5 13:57:35.391: mgcp_ds0_group_set_ds0_states
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/1
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/2
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/3
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/4
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/5
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/6
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/7
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/8
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/9
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/10
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/11
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/12
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/13
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/14
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/15
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/15
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/17
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/18
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/18
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/19
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/20
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/21
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/22
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/23
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/24
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:57:35.391: xgcp_endpt_default_set_state endpt S0/SU0/DS1-0/25
*Jun 5 13:57:35.391: xgcp_endpt_set_state endpt S0/SU0/DS1-0/26
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.06.05 19:37:45 =~=~=~=~=~=~=~=~=~=~=~=
show run
Building configuration...
Current configuration : 3028 bytes
version 12.4
service config
hostname MGC1
boot-start-marker
boot-end-marker
card type e1 0 0
card type e1 0 1
card type e1 1 0
card type e1 1 1
card type e1 3 0
card type e1 3 1
card type e1 4 0
card type e1 4 1
logging buffered 100000 debugging
--More-- !
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate slot 3
no network-clock-participate slot 4
network-clock-participate wic 0
network-clock-participate wic 1
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice-card 1
no dspfarm
--More-- voice-card 3
no dspfarm
voice-card 4
no dspfarm
controller E1 0/0/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
framing NO-CRC4
controller E1 0/1/0
controller E1 0/1/1
controller E1 1/0
controller E1 1/1
controller E1 1/0/0
controller E1 1/0/1
controller E1 3/0
--More-- !
controller E1 3/1
controller E1 3/0/0
controller E1 3/0/1
controller E1 4/0
controller E1 4/1
controller E1 4/0/0
controller E1 4/0/1
interface GigabitEthernet0/0
ip address 172.18.150.11 255.255.255.0
duplex auto
--More-- speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 120000
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
--More-- isdn incoming-voice voice
no cdp enable
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn outgoing display-ie
no cdp enable
ip forward-protocol nd
ip http server
no ip http secure-server
no cdp run
control-plane
--More-- !
voice-port 0/0/0:15
voice-port 0/1/0:15
voice-port 0/0/1:15
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.18.150.80
mgcp
mgcp call-agent 172.18.150.80 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
--More-- !
mgcp profile default
line con 0
password cisco
login
line aux 0
line vty 0 4
privilege level 15
password
logging synchronous
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
--More-- !
scheduler allocate 20000 1000
end
M
Hi Kailash,
Use the command "isdn bind-l3 ccm-manager" under the serial interface and let know what is the outcome.
Gagarin
The isdn "bind-l3 ccm-manager" command backhauls ISDN Layer 3 and higher layers to the Cisco CallManager. PRI/Q.931 signaling backhauls signals for processing from a PRI trunk that physically connects a MGCP gateway to a MGCP call agent. The ISDN lower layer information (Q.921 and lower) terminates and is processed on the gateway. The L3 information (Q.931 and higher) is transported over TCP to the CallManager(the MGCP call agent).
+++ Also, do a 'no mgcp' and 'mgcp' after you have added the above command.
Gagarin
i tried this command yesterday but it did not work 'bind-13 ccm-manager' it has other option bind-l2 ccm-manager .
rgds
KS
Kailash,
It did not work in the sense, you used that command and it did not work or you are not able to find the command at all under the serial interface configuration ?
Gagarin
