Not able to import new voicemail users to Cisco Unity
yeow_km
I have setup a new Cisco IP 7945G phone for a new user. Created new user for the user but I noticed that I cannot import the new user from Cisco Unity to create voicemail for this new user.
When I do import new user, the directory number for this new user does not exist.
Is there a limit on how many users I can import from CUCM to CUC ?
my CUCM is 8.5.1, CUC is 8.5.1 also.
V.Naveen Kumar
its related to licenses for voice mail user..
if you sufficient license then you can create voicemail user.
kindly check license available r not.??..
Jaime Valencia
And how are you importing the users?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
managed to solve the issue by selecting Primary Extension field in Directory Number Associations
default value was none.
