Community Helping Community
176
not able to login into CUC gui
Hi All,
i installed CUC in my laptop. during installation i put the same username and password for application/security/admin. i am able to login via cli and OS administration in GUI but not able to login into Cisco Unity Connection Administration in GUI. Could someone please help asap.
4 REPLIES 4
Hall of Fame Master
Re: not able to login into CUC gui
Highlighted
VIP Advisor
In addition to what Chris is offering, do note that they are two different usernames; OS Admin and App Admin? So, make sure to use the correct username/password pair for the correct login screen. You didn't mention it, so I thought I'd point that out.
Anthony Holloway
If you found this post helpful, please consider clicking that helpful button!
And for a limited time, by marking helpful posts, you're also helping Doctors Without Borders
Thank you so much Chris. You are right there was some typo error in admin username. Thanks much for your help
Hall of Fame Master
Excellent, good to hear.
Please rate all helpful posts and mark them as accepted solution if your issue is resolved.
Content for Community-Ad
FusionCharts will render here
