not able to login into CUC gui
Hi All,
i installed CUC in my laptop. during installation i put the same username and password for application/security/admin. i am able to login via cli and OS administration in GUI but not able to login into Cisco Unity Connection Administration in GUI. Could someone please help asap.
In addition to what Chris is offering, do note that they are two different usernames; OS Admin and App Admin? So, make sure to use the correct username/password pair for the correct login screen. You didn't mention it, so I thought I'd point that out.
Thank you so much Chris. You are right there was some typo error in admin username. Thanks much for your help
Excellent, good to hear.
Please rate all helpful posts and mark them as accepted solution if your issue is resolved.
