03-20-2019 05:27 AM
Hi all,
I'm not able to make outgoing calls, the first thing you hear is a busy tone.
Call attempt is stopped immediately.
Please find attached 2 test results in the attachment.
Also other relevant information:
voice service voip
ip address trusted list
ipv4 XX.XX.XX.XX 255.255.255.255
ipv4 1XX.XX.XX.XX 255.255.255.255
no ip address trusted authenticate
address-hiding
mode border-element license capacity 200
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol pass-through g711alaw
sip
header-passing
registrar server expires max 3600 min 120
early-offer forced
midcall-signaling passthru
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
voice class codec 2
codec preference 2 g729br8
codec preference 3 g711ulaw
dial-peer voice 10 voip
description Inbound from CUCM
session protocol sipv2
session transport tcp
incoming uri via InboundCUCM
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0/1
voice-class sip bind media source-interface GigabitEthernet0/0/1
dtmf-relay rtp-nte sip-notify sip-kpml
fax rate 14400
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
ip qos dscp cs3 signaling
no vad
dial-peer voice 11 voip
description Outbound to SIPSP
destination-pattern T
session target sip-server
session transport udp
voice-class codec 2
voice-class sip options-keepalive profile 2
fax rate 14400
no vad
dial-peer voice 20 voip
description Inbound from SIPSP
incoming uri from InboundSIPSP
voice-class codec 1
fax rate 14400
no vad
dial-peer voice 21 voip
description Outbound to CUCM
destination-pattern 71799..
session server-group 1
voice-class codec 1
fax rate 14400
no vad
- early offer disabled in sip profile (which is attached in sip trunk)
- , send Prack for all 1XX messages
- MTP enabled in SIP trunk
I'm a little bit lost, any help would be appreciated
03-20-2019 08:35 AM
On the logs I see State of The Call : STATE_DEAD and also SIP/2.0 503 Service Unavailable
You remove the IPs from the logs (which is fine for security, but next time just replace for something random like 5.5.5.5) so I'm not sure where is CUBE sending those messages but my guess is that it cannot communicate with the SIP provider IP.
Please check that.
Rolando A. Valenzuela.
