Not Able to Recieve Incoming Call Via PSTN
yogesh bhalerao
HI
I am not able to receive incoming call via my PSTN , Also i am not able to dial local call via my PSTN
I am able to dial STD and ISD calls but not able to receive incoming from STD,ISD
CUCM:- 10.5
Please find the traces
Dec 29 06:47:55.227: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x004C
    Sending Complete
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA18391
        Preferred, Channel 17
    Calling Party Number i = 0x2183, '9XXXXXXXXX'
        Plan:ISDN, Type:National
    Called Party Number i = 0x81, '901'
        Plan:ISDN, Type:Unknown
*Dec 29 06:47:55.355: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x804C
    Cause i = 0x8081 - Unallocated/unassigned number
I am having 4 digit extension :- 79XX
Any help would be appreciated
26 Replies 26
As per these debugs, you are sending 4 digits to the PSTN. 7942
I spoke with my Provider and he says you send me 6 digits and he will strip first 3 digits and will take last 3 digits , i created route pattern according to it but still the same
Do i have to create any Translation pattern
Dec 30 12:30:49.752: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0001
                Standard = CCITT
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '267917'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '244212'
*Dec 30 12:30:49.952: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8001
*Dec 30 12:30:50.412: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8001
        Cause i = 0x8281 - Unallocated/unassigned number
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Dec 30 12:31:04.692: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0001
*Dec 30 12:31:04.736: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8001
You are sending 6 digits to the provider.
What exactly do they require?
He said that you send me 6 digits i will strip the first 3 digits and use next 3 digits, Also i had informed him that for incoming you are sending us 3 digits and we changed the settings at our end so incoming started
But he says that also for outgoing he will strip first 3 digits and use the last 3 digits
Also i have made changes in the local landline pattern in calling party using the code and then 6 digit number
I don't think the provider is looking for you to change the Calling party before sending it to them. They specifically need the right Called number to route the call to the required side.
I just made incoming call to number 2679XX and in called number it showed 9XX the Translation pattern we created that day,
So basically what strikes me that "Called Number" they only require 3 digits
so for outgoing we would need to create Translation patter which will send 3 digits(last digits) to ISP and they will forward it accordingly
what u think ?
Just one more thnig
Local Mobile calls going through
 08:09:45.403: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0002
        Sending Complete
                Standard = CCITT
        Calling Party Number i = 0x0081, '2XX72XX909'
        Called Party Number i = 0x80, 'XXXXXXXXXX'
*Dec 31 08:09:45.547: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8002
*Dec 31 08:09:46.199: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8002
        Progress Ind i = 0x8282 - Destination address is non-ISDN
*Dec 31 08:09:49.935: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8002
*Dec 31 08:09:54.171: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8002
*Dec 31 08:09:54.179: ISDN Se0/1/0:15 Q931: RX <- FACILITY pd = 8  callref = 0x8002
        Facility i = 0x91A1130202008A020122300AA1053003020101820100
                Protocol Profile = Remote Operations Protocol
                0xA1130202008A020122300AA1053003020101820100
                Component = Invoke component
                        Invoke Id = 138
                        Operation = AOCDChargingUnit
*Dec 31 08:09:54.283: ISDN Se0/1/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0002
Local Landline calls not going
Dec 31 08:11:01.431: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0003
                Standard = CCITT
        Called Party Number i = 0x80, 'XXXXXX'
*Dec 31 08:11:01.535: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8003
*Dec 31 08:11:01.875: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8003
*Dec 31 08:11:11.755: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0003
*Dec 31 08:11:11.803: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8003
Can you find anything from this ?
That makes no sense..
Local: Called Party Number i = 0x80, 'XXXXXX'
Mobile: Called Party Number i = 0x80, 'XXXXXXXXXX'
Are you sending digits or only Xs?
As long as you adhere to their requirements in terms of number of digits and valid numbers, it is an issue on their side.
No i am sending digits
Local: Called Party Number i = 0x80, '257901'
Mobile: Called Party Number i = 0x80, '9999999999'
I changed the Called party mask and kept it XXX and see the below result i got
        Calling Party Number i = 0x0081, '2667267905'
        Called Party Number i = 0x80, '424'
*Dec 31 09:29:13.447: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8008
*Dec 31 09:29:13.795: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8008
*Dec 31 09:29:25.775: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0008
*Dec 31 09:29:25.815: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8008
This is clearly a provider issue.
I spoke with Provider yesterday he says that for outgoing local we dial 6 digit landline from which he will strip 3 digits and send rest 3 to destination
So in short he says that WE send him 6 digits and he wil strip 3 at his end and route the call
So do we need to create any translation pattern for it ? or make any changes in Route pattern
