AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
734
Beginner
Not able to send outgoing fax, in H.323 gateway
I am Aslam, in my client office they are not able to send (outgoing) fax. But we can receive (incoming) fax.
We have a H.323 gateway in the site, through FXS port fax machine is connected.
While trying to send a fax its showing an error "H3 - no answer".
Can anyone please help with this. its urgent
Aslam
5 REPLIES 5
Pleae post your Dial-peer and voice service voip configuration.
Beginner
Please find the dial-peer config below and help me to resolve this issue.
voice service voip
fax protocol cisco
h323
  no h225 timeout keepalive
dial-peer voice 1 pots
description ** incoming dial peer *
translation-profile incoming PSTN-Incoming
incoming called-number .
direct-inward-dial
port 0/1/0
dial-peer voice 2 voip
destination-pattern 3...$
voice-class codec 1
voice-class h323 3
session target ipv4:10.80.100.1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 3 voip
preference 1
voice-class codec 1
voice-class h323 3
--More--                            session target ipv4:10.94.100.1
no vad
dial-peer voice 4 pots
description **GSM calls**
destination-pattern 906[237]0.......
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/1/0
forward-digits 11
dial-peer voice 5 pots
description **Local Dialing**
destination-pattern 9.......
port 0/1/0
forward-digits 7
dial-peer voice 6 pots
description ** internaltional calls *
destination-pattern 00T
port 0/1/0
--More--                            forward-digits all
dial-peer voice 100 pots
destination-pattern 3059
direct-inward-dial
port 0/0/0
dial-peer voice 33 pots
description **Call to Emergency Numbers**
preference 1
destination-pattern 1[0-1][2457]
port 0/1/0
forward-digits 3
dial-peer voice 333 pots
preference 1
destination-pattern 91[0-1][2457]
port 0/1/0
forward-digits 3
dial-peer voice 300 voip
translation-profile outgoing international
--More--    preference 2
destination-pattern 900T
voice-class codec 1
voice-class h323 3
no vad
dial-peer voice 400 voip
preference 3
voice-class codec 1
voice-class h323 3
no vad
dial-peer voice 330 pots
preference 1
port 0/1/0
prefix 00
dial-peer voice 8 pots
description **National calls**
destination-pattern 906[145689].......
port 0/1/0
forward-digits 10
Highlighted
Beginner
Did you ever get a resolution for this issue? I am running into the same problem.
Jason
Enthusiast
Hi Aslam,
First of all, you need to clarify what is the complete call flow and all devices that are part of it, so we can have a better idea on what we are dealing with.
Please take a look on the following document with the most common Faxing supported call flows:
https://supportforums.cisco.com/docs/DOC-25210
You also better not use "fax protocol cisco" under voice service voip, it's kind of legacy FoIP procotol now a days.
We know that you have an H323 GW receiving the calls, what about the end device? Is the fax machine connected to a different router?
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Beginner
can u share your router configuration.
Content for Community-Ad
August's Community Spotlight Awards
